Constant840
- Mar 7, 2008
- 1,111
- 953
Before I pull it and head down to ask the pros at camping world, anyone have any ideas?
Thanks.
This. After you take off the old one you might find you could make the new one less intrusive also because they just used a stock one across all their models instead of adjusting the size for each model.I go get some metal and Fab one up that way it won't break again.
you could also make a fiberglass replacement pretty quickly using that as the plug.
No, that’s a chaputas, it goes over the chingadera.Chingadera.
View attachment 722394 View attachment 722393 It’s basically an interior shroud over the fuel fill. Beginning to let fumes in. Pretty thin plastic.
Thanks.
Exactly!! By thst part being broken or cracked, it should not cause you to smell any fumes.The problem is not the cover...
The problem is that you have a fuel leak somewhere. Get under the trailer and find the leak. You should not be smelling fuel anywhere.
And be Very careful. Fuel vapor is Very explosive!
Thanks for the repsonses. Haven't tracked a replacement. Other side has a sheetmetal version covering an exterior speaker so that may be the way to go.
As for the fuel leak, it was determined a while back to be a bad cap. My driveway is both sloped and off camber. I had opportunity to witness the cap leaking. I just haven't replaced it.
I wanted to find this part as it will never come up in one piece and do it along with a new filler neck and cap. The backflow deal in the filler neck is also MIA. I'm guessing someone tried to siphon from it at one time.
Try it on someone’s else’s phone. Bet it won’t be the same.Apparently after 4 years River Dave's Place has the top answers.......
Just go online and order it . Chances are if you try to find it local they will say we can order it for you … if you say ok , go ahead and order for me and give them all your info , and pay in advance , they will never call you when it comes in , if they even order it in the first place . Sadly this happens at almost every retail establishment these days .
