Luvnlife
Head Ram Rod
- Apr 11, 2011
- 12,268
- 6,032
Probably the best tri tip I’ve ever made. I started making my own rub so I might be a little biased.
Could have rested a little longer.
Sounds simple and easy. What internal meat temp do get with that. Roughly of course.We need to share cooking tips. Here is mine on a 4 pound tri-tip.
BBQ at 450, throw on one side for 5 minutes, cross hatch the grill marks for another 5 minutes, flip for 5 minutes, cross hatch the grill marks for another 5 minutes, wrap in tin foil and leave on a high rack for 10 minutes (in hot oven), then take out of the BBQ to rest it for 10 minutes. It's my version of the 10-10-10-10 method.
What is your method?
I like to pull mine between 145 and 150 then let it rest. I don’t like red.Sounds simple and easy. What internal meat temp do get with that. Roughly of course.
I’m always up for trying new ways.![]()
This one was so tender it didn’t matterLooks tasty. Just cut it against the grain on the next one.
Yeah, I wasn't going to say anything...I like to pull mine between 145 and 150 then let it rest. I don’t like red.![]()
That might be a little more than I prefer. I’m a medium/rare side. I don’t like mine bleeding though.I like to pull mine between 145 and 150 then let it rest. I don’t like red.![]()
Pull it at 135 thenThat might be a little more than I prefer. I’m a medium/rare side. I don’t like mine bleeding though.![]()
I've never measured the temp. I know the center cut is medium rare, and gets less pink as you cut to the outside.Sounds simple and easy. What internal meat temp do get with that. Roughly of course.
$8.50Just curious...what is Hottinger charging a pound for their tri tip? I know they are second to none!
X2. Never like smoked tri tip either. I also do mustard and most of time Montreal seasoning. Wrap it in plastic wrap over night and the next day grill it hot to sear the outside and turn it down to finish if off.I think because of the fiber and fat in tri tip it should be cooked HOT to start to break it down. I do not like smoked tri tip for this reason. I always rub it with mustard to again let the vinegar break it down, then season, sear hot and turn the grill down. And always cut across the grain.
Agreed. There's a big difference in actually smoking it and putting some smoke on it while it cooks. I think too many people try to treat them like a brisket etc...... when in fact they are more like a steak in fat content etc.X2. Never like smoked tri tip either. I also do mustard and most of time Montreal seasoning. Wrap it in plastic wrap over night and the next day grill it hot to sear the outside and turn it down to finish if off
That looks delish Pro tip if you want to enjoy it even better Cut against the grain Not with it. grain usually changes 2x in a tri tip. spProbably the best tri tip I’ve ever made. I started making my own rub so I might be a little biased.Could have rested a little longer.
