Uses of WD-40
TripleB
Exterminate roaches and repel insects
Don’t let cockroaches, insects, or spiders get the upper hand in your home. • Keep a can of WD-40 handy, and when you see a roach, spray a small amount directly on it for an instant kill. • To keep insects and spiders out of your home, spray WD-40 on windowsills and frames, screens, and door frames.
Keep wasps from building nests
Don’t let yellow jackets and other wasps ruin your spring and summer fun. Their favorite place to build nests is under eaves. So next spring mist some WD-40 under all the eaves of your house. It will block the wasps from building their nests there.
Remove strong glue
You didn’t wear protective gloves when using that super-strong glue and now some of it is super-stuck to your fingers! Don’t panic. Just reach for the WD-40, spray some directly on the sticky fingers, and rub your hands together until your fingers are no longer sticky.
Relieve arthritis symptoms
For occasional joint pain or arthritis symptoms in the knees or other areas of the body, advocates swear by spraying WD-40 on the affected area and massaging it in, saying it provides temporary relief and makes movement easier.
Relieve bee sting pain
For fast relief of pain from a bee, wasp, or hornet sting, reach for the WD-40 can and spray it directly on the bite site. It will take the “ouch” right out.
Clean dried glue
Clean dried glue from virtually any hard surface with ease: Simply spray WD-40 onto the spot, wait at least 30 seconds, and wipe clean with a damp cloth.
Degrease your hands
When you’re done working on the car and your hands are greasy and blackened with grime, use WD-40 to help get them clean. Spray a small amount of WD-40 into your hands and rub them together for a few seconds, then wipe with a paper towel and wash with soap and water. The grease and grime will wash right off.
Remove decals
You don’t need a chisel or even a razor blade to remove old decals, bumper stickers, or cellophane tape. Just spray them with WD-40, wait about 30 seconds, and wipe them away.
Protect your boat from corrosion
To protect your boat’s outer finish from salt water and corrosion, spray WD-40 on the stern immediately after each use. The short time it takes will save you from having to replace parts, and it will keep your boat looking like it did on the day you bought it for a long time to come.
Remove barnacles on boats
Removing barnacles from the bottom of a boat is a difficult and odious task but you can make it easier and less unpleasant with the help of some WD-40. Spray the area generously with WD-40, wait a few seconds, and then use a putty knife to scrape off the barnacles. Spray any remnants with WD-40 and scrape again. If necessary, use sandpaper to get rid of all of the remnants and corrosive glue still left by the barnacles.
Spray on fishing lures
Salmon fishermen in the Pacific Northwest spray their lures with WD-40 because it attracts fish and disguises the human odor that can scare them off and keep them from biting.
Keep dead bugs off car grille
It’s bad enough that your car grille and hood have to get splattered with bugs every time you drive down the interstate, but do they have to be so darn tough to scrape off? The answer is no. Just spray some WD-40 on the grille and hood before going for a drive and most of the critters will slide right off. The few bugs that are left will be easy to wipe off later without damaging your car’s finish.
Remove stuck spark plugs
To save time replacing spark plugs, do it the NASCAR way. NASCAR mechanics spray WD-40 on stuck plugs so they can remove them quickly and easily. Perhaps that’s one reason why WD-40 has been designated as NASCAR’s “official multi-purpose problem-solver.”
Coat a truck bed
For easy removal of a truck-bed liner, spray the truck bed with WD-40 before you install the liner. When it comes time to remove it, the liner will slide right out.
Remove "paint rub" from another car
You return to your parked car to find that while you were gone, another vehicle got a bit too close for comfort. Luckily there’s no dent, but now your car has a blotch of “paint rub” from the other car on it. To remove paint-rub stains on your car and restore its original finish, spray the affected area with WD-40, wait a few seconds, and wipe with a clean rag.
Clean oil spots from driveway
Did a leaky oil pan leave a big ugly spot in the middle of your concrete driveway? To get rid of an unsightly oil spot, just spray it with a generous amount of WD-40 and then hose it down with water.
JUSTWANNARACE
I will not let them take me🤣🤣
It also does well removing oxidation off paint.
WD-40 and 100mph tape(duct tape) 2 of the greatest inventions!
LazyLavey
Ive also used it to put a light coat over my engine to repel rodents. guess they don't like the odor
Happy Smitty
Boats love WD-40. Mine purrs when I wipe it's motor with the stuff.
buck35
Takes silicone adhesive off you're fingers when application goes awry. Tools as well before it gets up.
Mcob25rg
Didn’t know it would get rid of oil stains on concrete
