Whats the best product to wipe down the boat with?
Kfabe
i typically use vinegar mixed with water but would like to use something else to keep it clean. What are you fellas using for the wipe down?
DWC
Hot Sauce or Boat candy. Good results with both in the past.
X2 on the ceramic coat though. Bottle of water and some microfiber towels and clean up is pretty damn easy. My only mistake was to not do the interior. Saving up to get it done in the fall.
Kfabe
Have it ceramic coated by @Steak & Lobster, then use a rag and cooler water, or a bottle of water! Fock all that smelly nonsense!
I haven’t really looked into the ceramic coating. How does it work? Do you have a ballpark on price for a 255?
Rattle Can Lou
Lots....I use slick mist when I pull out and the water is fresh..it works great..if it sits and hardens up I use Spot b gone they sell at Spanky's. It's like 12.00 a bottle but you bet several applications. Never used the hot sauce products but I'm sure they're good..
HALLETT BOY
Soft water
Yep , soft water in a bucket, with a microfiber sponge , best way to make wax / coating last . On the swimstep or rear of boat with stubborn water spots , then a commercial product like Hot Sauce etc .
BassLakeCruiser
Lucas slick mist like RCL. Chemical Guys has a boat line I’ve tried but keep going back to Lucas.
BassLakeCruiser
I’m not sure anybody in the Fresno area sells boat candy or hot sauce whatever it is. I’ll try anything twice.
BajaMike
50% cheap white vinegar (buy by the gallon, its about $1 to $2 per gallon) and 50% DISTILLED water (must be distilled, it has no minerals in it....minerals are what create water spots). Put it in a spray bottle. Easy and cheap, and works great. Also works great for cleaning car or home windows.
Bullet28
Nor Cal Delta
I had my Bullet ceramic coated for me the only way to go, Randy and his team do amazing work.
Prior to the coating I used Boat Bling.
240Hallett
Lake water on a wet towel followed by a dry towel. Obviously works best at the ramp while it’s still wet.
707dog
slick mist by lucas oil or cooler water and 303 on interior.... did use the OG boat bling for many years great stuff
Howardflat
Bad MFer
Was this just a post to see if you were banned from your last thread you started?
Activated
Deplorable
