jetboatperformance
- Jan 1, 2008
- 9,005
- 20,165
Cherokee 20' WJ/Berkeley swap part #1 . This looks to be a "one off boat" likely built as a V drive hull but rigged as a Jet . The Jacuzzi WJ sustained a catastrophic thrust bearing failure , bent the pump shaft and blew up the driveline , the intake had been set in silicone (not epoxy) . There was marine plywood in the intake rectangle that require remediation more to follow .....
