XR to SCX conversion
Boat 405
Wanted to update a few folks on the swap. Info that some of which I found, some I had to do some digging.
First off the true weight difference of the two drives is 55 lbs. In perspective that is about 8 gallons of fuel or the average sized family dog. So really no big deal.
Full XR drive built from Max Machine with an IMCO SC -2 Lower with +12" driveshaft with all the goodies with oil. 131 lbs.
Full SCX drive from IMCO with dual downshaft -2 lower with +12" driveshaft with oil 186 lbs.
Somewhere I read 80 lbs difference... Not sure how that rumor came about.
You can run a 1 7/16" propshaft on the dual downshaft lower and keep your bravo props. IMCO sells a prop hub adapter to run a bravo style prop on a 1 7/16" shaft. (Had I known this I would have ordered the dual down shaft lower with the larger 1 7/16" shaft over the std 1 1/4" propshaft.
Other must have items, a helmet change, no big deal most people know this. An HP gimbal ring or IMCO's gimbal ring or their complete transom assembly. A larger oil reservoir. The scx drive with dual downshaft lower holds 5 quarts of oil. A complete XR with sc lower holds about 3.
You do not need to use a manual trim gauge when switching to an SCX drive. Teague sells a kit that makes so you can use your existing trim gauge. https://teaguecustommarine.com/em0011/digital-trim-indicator-actuator-kit-imco-scx You'll also need a 0-5 volt to Ohms converter box from Mercruiser. Mercruiser PN 884359T 1. It adapts 0-5 volt output to Ohms so your existing trim gauge works.
EBT531
Is there a reason you didn't go to the IMCO gimbal ring? I ask because whoever did the swap on my boat did not swap to the IMCO either. I saw the two side by side today and the IMCO is significantly beefier.
Boat 405
The only reason was because I found an HP gimbal ring brand new old stock last season for a song.
ToMorrow44
27 Advantage TCM 800efi
Good info. How much power are you going to be putting thru it?
woodagain
View attachment 760652 View attachment 760653 View attachment 760654 Wanted to update a few folks on the swap. Info that some of which I found, some I had to do some digging.
I’ve seen your boat at KMG, he really
Did a nice job on it.
What gear ratio and prop are you planning to go with?
Boat 405
Thanks, I'm really happy the way the cap turned out. Right now I have a 1.5 Gear ratio and a 30P prop.
Boat 405
Not with the new drive. Hopefully this weekend.
Boat 405
Another tip. When you make the change. Always use the factory shift cable. I made the mistake of buying an aftermarket cable and it didn’t want to shift correctly. I put the factory Merc cable in. zero issues.
The new cable is on top. The factory Merc on bottom.
Boat 405
Went back to an SCX/SC-2. Boat would not plane. Took forever and about 4000 rpm. Sc 2 planes instantly at 2600 rpm. Also lost 12 mph on the top end.
River Dirt 2
Brummett 21
Thanks, that’s what I’m experiencing as well. Was hoping there was a way to make it work...
Boat 405
I tried 5 different props. Zero change on planing ability.
Right now with the SCX and SC-2. I’m running 109 on GPS with a stock 30 bravo prop at 6300 rpm. Very happy overall.
River Dirt 2
Brummett 21
Yep, tried 5 different props as well, too bad looks like a nice piece, just not the “missing link” we thought.
Did you find a new home for the lower?
ChrisV
Do you have to change the shift cable for the conversion?
Boat 405
No but you do have to cut the nipple off the end of the shift cable where the threads stop.
OC Daytona
Was a 30 Merc labbed 4 blade one of the props you tried?
My Daytona always gets on plane smoother and faster with Merc labbed 36s and is also a good 8 mph on the top end.
The labbed props work better for me in every RPM range using Imco SC's and Merc -2 Sportmaster lowers
The only reason I put some standard 36's on was I pitched a blade during Covid and couldn't find a new set of labbed 36s :confused:
Boat 405
Yes. Two of them
WYRD
I have a 600sci and scx/sc switched from a merc 4 blade to the max5....planed much better
pkrrvr619
How did the top end change?
I have a 25 and run a 32 4 blade and a few people have said to go 32 5 blade.
WYRD
I don't really know. It's a new boat to us so I have not played around with maxing it out yet. Previous owner and research here indicates the boat did around 87 mph with a Bravo 4 blade 28p. I did have it up to 80 with a little room left but I had the family on board so iwasn't really pushing it or trimmed out. Still getting to know the boat but I will say I was impressed with the max 5 28p.(except the cost🤑)
pkrrvr619
Besides planing did you notice any other positive effects?
WYRD
It was definitely smoother however the four blade I had was nicked pretty good so I'm sure there was vibration from that. Other than that probably just placebo effect because I spent a lot of money on it.
Rkc
Is there a specified break in period for the scx? I’ve tried to search but came up empty. Under certain rpm for amount of hours etc? Or is it just install and let her rip
pkrrvr619
Hammer down! Jk I didn’t break mine in for any specific time but I didn’t go out and flog it either for a few trips.
Rkc
I guess I don’t search as well after beers all night vs clear headed in the morning haha.
Found this through imco if anyone else needs it.
