[WTS] 2.4 merc bridgeport
Nielmcque
2.4 Bridgeport power head fresh fully rebuilt wh46 carbs carter fuel pump with jegs regulator. Motor has less then 20 hrs on rebuild but lost a piston due to possible over propping. Was still running. 1000 bucks
Nielmcque
Still for sale make offer it's on a pallet ready to go.
Nielmcque
I also have a 2.4 mariner efi 220 that needs a rebuild for sale whole or for parts has 20 inch mid and lower with nose cone and low water pick up
obnoxious001
Engine building character
Where are you located, how much for the Mariner, and what's hurt in it?
Nielmcque
Lost one cylinder. I dont think it has been rebuilt since it left the factory. Had original oil pump on it when I got it and appeared to have never been opened up till I did.
Nielmcque
I'm located in California between temecula and palmsprings
Is that the Mariner that was on it when you got it? Had the dual pyrometers in the exhaust manifold?
Nielmcque
Everything still for sale some one make me an offer and come pick this stuff up.
Nielmcque
600 for the Bridgeport
500 for the 220 efi with 3 ram mid section and clam shell cowling.
Nielmcque
Land and sea jack plate is also for sale needs new seals $100
Nielmcque
Bottom left cylinder is down below 90psi compression piston messed up dont know how much it damaged cylinder wall. I believe it's a 1988
Blownbillybob
Will be down that way next wed might want to come by and look at it
Is it all apart or complete engine assembly
Nielmcque
I pulled the head and separated it from the mid . And I robbed a few parts from it. Give me you phone number I can text you some pics later today.
