A pair of tailpipes
mattyc
Did these tailpipes for a buddy. .065" wall 304. Spent a great deal of time taking measurements and doing the math for a good fit and tight joints. Never welded something like this, it was definitely a learning experience.
Guest06
Bad ass bud, single wall right? Time to get out the Mother’s and clean them up.
mattyc
Thanks, yeah no jacket, these will go with a set of cmis on a 496. The cmi headers dump the water at the end of the collector. They are at the polisher now
HNL2LHC
KEEP REGOR FREE!!
Nice job. What are some of the things that you learned?
mattyc
Thanks. I already knew this so I guess you could call it reinforcement; measure twice, cut once, preparation is key. An accurate, tight fitting joint produces a much nicer welded connection ( especially for an amateur welder ).
Learned better torch and amperage control, big deal when welding thinner materials.
Learned about purging, and why its vital to stainless tubing joints. If I end up doing more of this, I'll put together a better purge set up, I used a lot of gas purging these. Thinking I could waste less and achieve good results
HNL2LHC
KEEP REGOR FREE!!
Thanks for the information. Have you spent much time welding before this? I ask all because I want to pick up torch once more. I started back in the day brazing then welding. I have also done stick and mug.
I assume that you are doing right and that is what I am after to do as it is the one I have not done.
Are you in Havasu? If so I’d like to check out your set up some time.
mattyc
Very little welding experience prior. A little bit of mig and now learning tig. Had the welder next to the shop I work at give me some pointers, reading and of course some you tube.
I live in temecula, so if your wife decides you guys need to go wine tasting give me a shout
HNL2LHC
KEEP REGOR FREE!!
We are in CA often. Might have to reach out when we are in the area and have some time. Would it be during business hours or a time after hours?
mattyc
Weekend is best, at work during the week. Shoot me a message when you're headed this way
