Another Bronco Thread :{]
Groper
Well this Bronco isn't even close to RB's & Dezrider Bronco's but should be fun to drive.
I was about to purchase a Bronco in either stock form or a partially built Bronco to do a FULL build BUT after talking to a few shops and getting into a Q for a build was more than 6mos out and then of coarse the build time that will extend way past the scheduled estimate. :rolleyes:
So after some horse trading I ended up a Bronco that doesn't need anything the previous owner(s) pretty much did everything I would have done if I were to build one from scratch.
Immediate plans are to paint match rear fenders, two tone paint (Gray) midsection down the side like the factory looked, Powder Coat front and rear bumpers gunmetal gray. Replace the carpet with a rubber floor.
Pipe dream, fabricate a new dash, console, gauges re-wire and maybe some HP.
1990 Bronco XLT trim w/92-96 front clip
Full Caged front to rear all tied in together and Rhino Lined.
Mastercraft seats with rear bench
Mastercraft 5pt harnesses
Lowrance GPS
Roadmaster radio w/ PCI int.
Safecraft Firesuppression system
Autofab hood
Fiberworks fenders
BD XL80 Leds
17" Method Beadlocks
FORD 351 Windsor crate motor
e4OD built with billet Torque conv with Art Carr shifter
Short tube headers
Canton alum. rad catch can
CBR large trans cooler w/fan
PML High Cap trans oil pan
Autofab eng & trans mounts
Slip yoke driveshaft
Front Suspension (new)
Ohhcho Fab 4.5" over trussed I-beams
Ohhcho Fab single swing steering with double sheared spindles and pitman arm
Warn Locking Hubs
Currie Axles
Yukon Gears 4:88
Fox 2.5" C/o's
Fox 2.5 Triple Bypass
Fox 2.0 Bumps
Howe Ram assist with PSC res.
Hollander Fab w/ 14" rotors
Wilwood calipers
Rear Suspension (new)
Currie F9 Full Floater 9" w/disk brakes
Yukon Gears 4:88
Spool
Currie Axles
BMS skid Plate
Deaver Q80 Leaf's
4130 Extended Shackles & Hangers
Fox 3.0 Triple Bypass
Bilstein Air Bumps
c_land
Nice ride. i want to do the grey stripe on mine and color match the fiberglass top.
The Oh Cho bronco he has now looks great with the stripe.
Groper
In Andrews shop or it's his ?
I'd like to see what it would look like with the top done, I was told that the off white on this Bronco is a factory color but don't remember seeing one like this though I think a Metallic Gray should look fine with this shade of white. A burnt Orange would also go with this white as well imo.
c_land
I’m not sure whose it is but it looks great
LBsuperJET
Well-Known Inmate #1155
Wow, nice find man! I wish mine was this built out but im stoked to have what I found a few months back. I am contemplating having Oh Cho do my new beams. Either him or Desolate is going to do them. I would like to afford going wider too. Thats a badass Bronco man.
You got a sweet ride! At least an excellent start!
all the boxes have been checked for a long and solid prerunner
