Skee
Unknown Member
- Jul 20, 2008
- 2,348
- 70
Ok :blah:
I have a question,hopefully one of you'se guyz can help me out...I need a starter for my 77 Spectra 18 with a 460... I'm not a "baller",so I can't afford a super expensive one
..so I was just gonna go to the Zone...:rolleyes...The question is...How do I get them to look me one up? I mean what kinda vehicle?:rolleyes I just pulled the old one out and even tho it's a Ford engine...it say's American Motors on it.... Can I just tell them to look like an old Fordt truck or something? Thanks....
Your starter is shot. Stick a perma mag on it instead of the big and heavy OEM style and it will be much better for you. They are a gear reduction starter and deliver much more cranking power than the oem. Call the guys at DB Electrical and they'll help you out. 800-753 2242 Have your starter off so you can describe it to them.Bart....The battery is new,the solenoid is new,as are both of the cables....it starts fine when it's cool...once it
s warmed up the starter doesn't work so well :rolleyesAnd Thanks for the help everyone..it was pretty easy! :thumbsup
have them check the stater first to make shure thats the problem grounds are the problem alot if it looke like an old ford stater just tell them 76 460 and compare
Hope you enjoy driving around a bomb.
Marine starters are shielded to prevent the sparks from igniting any fuel vapors in the engine compartment. Same with alternators and distributors.
All of those things create sparks in normal operation. There are mesh screens in any openings on marine units so that when the sparks meet fuel vapors, the explosion is contained harmlessly within the component. That way your whole boat doesn't blow up.
And since you're in the habit of putting cheap automotive parts on your boat, chances are your fuel pump is also suspect. Meaning that when the diaphragm goes, it'll leak gas out of the weep hole into the bilge, rather than being being routed through the carb.
When it burns and the insurance adjuster comes out and discovers the Auto Zone stuff that you put on it, coverage will be denied.
I don't want to sound like an alarmist or anything, but in the dozens of boat fires/explosions I've investigated over the years, mostly in vintage boats, the cause is most often traced back to automotive parts.
With all the money we have sunk into our boats, why put it all in jeopardy over a hundred bucks or so?
So You have to ask yourself. Do you fell lucky?
Wow are guys kidding me right now!! My boat never leaked a drop of anything because I made sure it was tight as a drum!! I can see inside an enclosed engine hatch it could be a problem! Open engine you couldn't start a fire if you wanted too!! And by the way most engines back in the day were all automotive no marine shit at all!! 60's 70's!! My dad and all his friends did just fine!!
Have we come a long way sense than, sure but that doesn't mean the old way was wrong....
I say open engine hatch Auto zone would be just fine!! As long as your not leaking gas all over the place!! In which your headers would probly be the first ignition source anyway!!
If your really worried about it put silicon all over your connections!!
Again I had my boat 14 years ran the shit out of it as a young 21 year old and never had one issue.. Luck!! Not in my family!! Not everyone is rich and paying 300 for a stupid starter is ridiculous!! JMO!!
I've been a boat mechanic for longer than you've been probably alive and haveThank's jetboatmatt! I like and agree with your response 110%!! :thumbsup
NEVER once put anything on a clients boat or my boats for that matter, that wasn't CG approved. Have you ever witnessed a boat explosion or seen a boat burn to the water line, not a pretty sight. That's why I recommended a marine starter earlier in your thread. I wish you well my friend!!!
I usually check out when a tech thread goes sideways like this one. However, this is a matter of safety, so I am going to try once more.
A) As stated, it's not the fuel its the vapors (fumes), so yes, you absolutely can start a fire with no effort at all. You do not need to have a fuel leak to create fumes in the bilge. On carbureted engines, which is what the OP has, they are vented out of the float bowl vent tubes as long as there is fuel in the bowls. Period. Vapors are heavier than air and go straight into the bilge and lay there just waiting for an ignition source.
B) You are mistaken about back in the day. Aeromarine '60's, Hardin Marine and Harman Marine 70's, OMC, Mercury Marine, Volvo Penta, etc. used USCG parts. The few that didn't were the minority.
C) The headers would never be the first ignition source. It is the starter and alternator. (sparks)
D) Silicone over the connections..... not the problem. Again, it's the spark.
E) Marine starters aren't $300. A good bottom mount Ford Marine starter is about $200. Even if it was $300, what is a life worth? And on top of that, it will long outlast any Auto Zone starter pretty much making it a wash cost wise.
You have Boatcop who has no doubt first hand experience with boat explosions and the cause, Froggy, a very knowledgeable man and a past owner of a boat mfg company, Boatdoc, and myself, a 40 year marine mechanic with the highest level of certification you can achieve from Mercury Marine, all telling you it is life threatening. Seems like a lot of good advice to me.
This response is not pointed at anyone in this thread, even though I quoted a response. It's for the people reading this thread that might actually be swayed to purchase a part that could potentially cost them, a loved one,or bystander, their life.
Is there any issues with taking your original marine starters and alternators to the trusty guy who rebuilds those for a fraction of the cost? I have always gone this route when possible, but I don't know if there is a downside to it.....
I read Alan's post five times now and I can't put together why the harsh response towards him?
No, I'm not 75 years old, might feel like it sometimes, but used that language to try and instill what I and several others on this board have been hearing for well over 30 years. Auto parts on boats are NOT to be used. I hope you never have to see the aftermath of a boat explosion/fire, let alone be involved in one. My friend, it's not a very good deal. Please be safe, that's all I ask.Mechanic longer than I've been alive? What...are ya like 75 or something? :eek(you don't know me or my age)
I always thought marine stuff was just water proofed as to not rust out!! After my third starter I was pretty over it!! I was going to go Marine when that went. It never did then Sold the boat..
Had no idea there were built in spark arresters inside starters!! Thanks for the education!! Moving on!!
First of all...I'm gonna apologize to Boatcop...Anyway...I don't know why I even asked this question here... I have been boating for many many years..Hell..I myself have owned 11 different boats..covered hatch,uncovered hatch,outboard (mistake),dry stacks,wet stacks,inboard water cooled exhaust,inboard/outboard..I've pretty much had 'em all....I have been boating for over 35 years....I have had Marine parts,I have had Autozone parts AND I have had Alcohol (booze) in my boat,along with my kids and Family..all at the River the whole time....I have NEVER had a Safety issue....I have NEVER had an accident of any kind AND I have NEVER been bothered by the Po-Po....I guess what I'm trying to say here,is......I know how to boat,I know how to fix 'em (properly,without any issues) and I know what is right for not only Safety issues,but what it takes to fix a boat correctly too! I Thank you all for your input and I apologize for the thread going south.....Anyway,I put the Autozone starter in and I will leave it in as I have used them in the past and all is and has been good! My little Spectra has the hatch cover but also has a USCG approved fuel pump and air filter,also my vent fan work's excellent and is used properly EVERY TIME......I am ANAL about keeping my bilge area clean and leak free.....So,hopefully I will not "jinx" myself with this post and will continue to have a Safe and Fun boating experience as I have for many years.... I hope you all do too! Peace! Skee...![]()
You should strongly reconsider using a non- marine starter in a closed engine hatch. I'll leave it at that.
OK...now my curiosity has got the best of me....If I were to look at an Autozone starter vs. a Marine starter (visually) what is the difference (from your perspective) that I'd be looking for? I am just curious to see what happen's here....
The Coast Guard just didn't wake up one morning and say: "Hey! Let's make some regulations that will make boat parts more expensive, just to fuck with boaters and boat builders."
There's are reasons that we, as marine enforcement officers, do accident investigations and reconstruction of boating mishaps. The main one being to make boating safer. Those investigations and resulting regulations, standards and laws have been responsible for reducing boating fatalities from around 1,700 in the early '70s to around 700 or fewer today, even while the number of boats and boaters have increased 10 fold. We went from 40 deaths per 100,000 boats in 1965 to 5 deaths per 100,000 boats today.
It's true that motorheads of the '50's and early '60s pioneered putting automotive engines in boats. It's also true that a lot of boats blew up. In reviewing those investigations it was discovered that automotive components, which inherently cause sparks in normal operation, were igniting fuel vapors, blowing up boats and killing and severely injuring people.
To reduce and hopefully prevent that, the Coast Guard introduced regulations, such as J tubes in carbs, screening in starters, distributors, alternators, and return tubes for fuel pumps. Not to mention fuel hoses and connections, electrical connections and bilge ventilation. And as a side note, marine techs who put or use those parts on their customer's boats are 100% liable for any fires, injuries, property damage and deaths caused by those parts. Owners who put them on their own boats are also liable for any injuries, etc. to their passengers in case of explosions or fire.
Can someone go a whole lifetime without marine equipment and not have an issue? Sure.
But do you want to take that chance? Do you want to purposely place your family and friends in danger? You may keep your bilge and engine compartment so immaculate you could eat off it, but anyone who's turned a wrench on an engine knows that shit happens. Even the pros, NASCAR, NHRA, F-1, etc., have leaks and fires. What makes any novice think that they are exempt?
I'll get off my soapbox now, and just say that hope that the next boat fire I, or my compadres, have to investigate isn't yours.
