Differences between the Berkley Pumps
farmo83
So what exactly are the differences between the berkley pumps. A,E,J etc ? Any info would be greatly appriciated.
jetboatperformance
Been "alseep at the wheel" here ! Heres some info from my prior post's an my M/S blog ! Tom
Basically E and F pumps (Transom mount) are what we call "insert jets they require a mold insert in the hull during layup, they were very popular at the middle 70's and into the eighties, they were quick and simple to rig and work well , popular in Taylors, Glastrons etc most parts ,with the exception of suction piece and steering components will readily swap between most Berks and thier "Clones", the only real difference between E and F is that the F had a gimble "affair" that allowed for Trim (jet-ovater) A,B,C,J and Gs (standard "drop thru intake types") are all very similar as well , some early A and a few B's have a longer shaft and different designs at the bearing cap, rear bearing seal (none) and The Suction its self , All split bowls will swap and the G is considered the best for the ability to accept bolt ons and "flow". We (JBP and others) are now producing a modified "C" split bowl however that we belive will out flow the G as we know it. (PHOTOS BELOW)
Heres some info from my Blog for now and I'll post up more later :
(Blog post Berkeley vs Dominator)
11/15/08
The two Basic jets (12 jg/c Berk and Dom 12s) are very similar and many parts interchange between them Some diffences like Omar said are wear ring shoulder size and design and the grease slinger behind the frt bearing . With the exception of the very early Berks (12 A&B) ,all Berk 12j models including the E&F use virtually them same parts for repair . Dominator has "morphed" periodically over the years ,making changes to wear ring OD sizes and designs . Rebuilding the large number jets as we do find there are "pitfalls" and its critical ,for example on Dominator to know serial s for parts replacement accuracy. Omar is also correct on the "water lube" brgs on early Dom jets , now they have a snap ring retained double greasable seal vs Berk which uses a 90 wt oil reservoir. Lots of other jets (Aggresor, Legend A/T,Bayjet) and thier parts will also "swap" between each other but sometimes have fit and tolerance issues to be aware of sometimes requiring modifcations, lathe and mill work . Most of these Jets will all bolt to the others suction pieces (even Bayjet with some work ) As far as Pure strength goes ,my weapon of choice among them is always Dominator for its casting design and thickness on the suctions and bowls . Dominator/AT also is a company who is always "moving forward" working on new products and improvement , we use/install alot of the Dominator HP intakes and although the design is not all that much diffenrent than the original Berk we find it a beautiful piece and "cake to install and set up . A Dominator 12s with a 17-4 shaft and Stainless impeller with hold up to Mega HP with very few other Mods . More info if you need or want it Tom@JBP
authorized Dominator A/T dealer
