Chili Palmer
Master of My Domian
- Jan 7, 2010
- 12,073
- 25,181
I've got a 2011 Silverado 2500HD with the Duramax engine. I took it in to a well respected diesel shop in Chino and had them replace a leaking water pump. When I picked it up a check engine light was on, I figured because they disconnected the batteries, so I used my Edge Insight to check and clear the codes. I drove home without any issues, but when I got home I shut the truck off and it started to diesel like a gas engine, so I turned it back on. I turned the key off and it continued run and the check engine light kind of glowed. I'm like WTF? So I turned the key on again and turned it off and it sputtered a couple of times then shut off. I turned the key on without starting it up and checked to see if any codes came up again and the same codes that I erased were back:
U0140 - Lost communication with BCM
U0121 - Lost communication with ABS control module
P163C - Unknown
P0650 - Malfunction indicator light control circuit
U0106 - Lost communication with glow plug control module
P0381 - Wait to start controller
I unplugged and replugged in my Edge unit, reinitialized it and cleared the codes again and started the truck. It started and shut off like it should. I took it around the block and shut it off and it worked fine.
Now fast forward to this morning - I get to work and it won't shut off again. After turning the key off and on a few times it finally shuts off after it diesels a few times.
I called the shop and they tell me to bring it back in. That's fine, but everything was running great before I brought it in, and now this.
Has anyone out there had this happen to them before?
P163C - Unknown
