C-2
- Sep 26, 2007
- 12,894
- 8,935
I'd go with this stuff
Yes. Swedge/swage. You'll also need the jaws that go into your vise to get that dealio closed up correctly. I doubt that you can get it to hold by crimping the swedge/swage with a pair of pliers.
I can't readily find what type of crimp I would need.
Any ideas?
Buy new cables. Less than ten bucks.
http://www.homedepot.com/p/Ideal-Se...i_kw=&ci_gpa=pla&ci_src=17588969#.UmSTD3Aqj7o
I'd sell the house and buy a new one with a decent garage door opener and no horses.
That's just me.![]()
Thanks for that. I saw those, but think they are "safety" only cables; meant to help pull, but mainly to stop a door in case the torsional spring snaps?
I have an old fashioned door, f*in thing weighs a ton. It's a chain drive/cable system.
You are correct, that "pair" of cables is for a modern sectional garage door.
Actually, on a torsional door the cables do all of the lifting. The springs and drums are on an axle in bearings, and the only attachment to the door is the two cables.
I was involved with the door and gate business for 50% of my life.
Thanks Barry. If the cables are the same thickness, I am guessing they could be used primarily for lifting?
I'll measure my cable and see if it's 12'; otherwise, I still have to loop an end.
A word of a advice from an old man whose been there before.....Call an overhead door service and get it fixed right and tuned/adjusted correctly. You'll pay out a few bucks, but be done with it.
