How tall is your Tritoon/Pontoon??
YeahYeah01
We're looking at houses and down the road I can see us in a Tritoon but want to make sure an average Tritoon will fit.
I know there are a ton of variables with manufactures and trailers, tires, ECT.
Edit: with Bimini down lol.
Just looking for some numbers to get an idea of what will work for us.
Thanks!
thedan
My 2006 Lowe’s tritoon is 8’4” to the top of the windshield.
DRYHEAT
My tri-toon is 12‘10“ sitting on the trailer with the Bimini top up.
if it were me I would look for an RV garage with a full 14 foot door for resale down the road. The bigger RVs are going to need it.
YeahYeah01
Thanks! That's what I'm looking for but super limited inventory in our price range.
YeahYeah01
both mine are 9'.. i'd say get 10' or 14'
Thanks! Trying to lol. Inventory is low unless I had a half mil laying around. So just want to make sure that if I found something with a 9' that I would have a chance to fit one.
CanyonLakeDave
Mine has triple axles w/
20” wheels and a hardtop so it tops out around 13’6”....regardless of what you buy I agree the 14’ door is standard nowadays and best for future resale.
throttle
c ya on da lake
With the bimini and arch down, mine just fits under a 10’ header.
It’s easy and electric, but sometimes I find it just to be a pain in ass. I would rather just back it in and never have to lower the arch. I would need at 14’ door to do that.
Bummer is, after thinking I had a house with big garage this proves me wrong. Luckily at least it’s 60’deep.
YeahYeah01
Thank you sir.
I guess twofootidus applies to boats and garages.
I think I'm just going to have to patient until something comes up with a 14' door.
tostark
Liquid Equity
My playcraft barely fit into my 8’ door with bimini down, Driver seat reclined and i would reversed the hitch so i could raise the front end and lower the back. Also, having a pretty level driveway was important. It worked, but way too stressful and i eventually remodel the garage to RV
SLT Kota
24' sun tracker pontoon 8'10" tall, 8'6" wide and 34'4" long. I'm glad we went with the over sized height AND the over sized width since I don't have a straight shot backing it in.
YeahYeah01
How long is your with the trailer?
Might have found a RV height but i need to measure the length when we go see it.
YeahYeah01
Your trailer is 10' longer than your boat? any idea if that is super common on for pontoon/tritoons? I wonder if they make swings away necks for them.
SLT Kota
Yes, it is but it depends on how you measure the boat. Sun tracker calls it a 24' boat because the deck is 24' 1" but the actual length of the boat overall is 26' 2" because of the setback for the engine. Once you add the engine, stairs on the front of the trailer, and trailer tongue (no swing away on mine) it takes up a lot of room.
I've noticed the front of the trailer is longer than my last traditional boat for more room between the boat and truck during sharp turns since the front of the boat is squared off, the stairs on the trailer make it less noticeable when looking at it.
I went back and checked the specs and the tritoon version of my boat is actually a few inches longer and a few inches taller than the pontoon version that I listed before.
The tritoon version is 9' 1" tall, 8' 6" wide, and 34' 6" long.
Sun tracker has the specs for each model on their website which might help for a general idea of "package size" for different size pontoons.
Here is the one for mine:
YeahYeah01
Thanks, this helps a lot.
The house we are looking at has a 30' deep RV height garage in the center and 2 standard size on both sides of that. I need to take a good look to see if its possible to extend it without getting crazy. It's a 1000 SF garage but built in the 90's before all these giant boats and rvs lol.
DRYHEAT
Sorry it took so long to get back to you I was working. I’d have to measure mine mine is a short pontoon 22 foot but I think it’s close to 30 feet long sitting on the trailer, I do not have a swing away tongue.
YeahYeah01
Thanks man!
throttle
c ya on da lake
My tubes run right to the end of the bunks on trailer, it’s called a 25 but it measures just under 26’ (has some deck overhang aft of the tubes).
Other things relating to length of trailer or things to think about with 30’ garage... the outboard motor and the boarding steps on front of trailer make mine just under 35’ long.
You can definitely have a swing away tongue made to shave off a bit. But things could get tight.
YeahYeah01
Thanks for the advice. I'm going to see it person and measure my self.
