Hvac folks
jetboatperformance
My 40 year old Coleman furnace has been “Stellar” thru out the years , last year it made a squealing noise when we first started using it and this year it did as well. bit worse It’s clear that it’s coming from the big motor that’s in the picture. I’m just wondering if anybody can give me an idea of how difficult these things are to change it doesn’t look complicated.
very simple to replace a motor. Take a couple pics first. Setting the motor back into the housing need s o be close to the same, not necessarily exact. Most common is a 3 bolt setup on one side with a belly band around the motor. Most likely a single speed motor if its that old and just a furnace. As long as the motor frame size is the same, more than 1 speed is fine. You just wont use the others. All the motor info should be on the tag on the motor.
If everything else on the 40 year old unit is in good shape (heat exchanger, gas valve etc) changing the motor isn’t too bad if you have the right tools (blower puller, etc) all you have to do is pull the motor, find a match (specs are on a sticker on the side) and then when it shows up reassemble everything and ensure it’s aligned and balanced.
I will say the likelihood of a 40 year old heat exchanger being in safe operating condition is slim to none. This stuff is designed to last 10-20 years max. 30 if you maintained it correctly. (The two years of letting it squeal and run at a lower speed than designed put additional stress on the heat exchanger).
Short answer…yes you can check he the motor and send it, could there be bigger safety issues? Yes.
I’ll put it like this. A guy brings in a 40 year old jet bote that hasn’t been maintained and asks how easy it is ti do an impeller…..what’s your answer? 😂😂
Coleman was the last to give up fan belt drives on domestic furnaces.
If you got one of those beauties, check to see if that is the NOISE issue.
I had the exact same blower in a single wide. The original motors had oiling ports so you could get a bottle of sewing machine oil and squirt some in and lubricate it. If that doesnt do the trick then pull the blower and get the motor plate details and order a new one off Amazon
I have swapped a few of those back in the day.
Not hard at all. Use sand cloth on the old shaft to remove surface rust and soak in wd40 before trying to remove the squirrel cage (blower wheel)
Dam 40yrs old I just replaced everything because it was 20yrs old..
Back
