Lance camper question
spectra bash
Do you guys travel with the propane on so you can run fridge? New to the game.
wash11
Off The Grid
Thanks. Just pulled the tanks and had them filled. Replaced the lines also. Was reading inside of door and it said valve should be shut off while traveling.
I'm sure the smart thing would be to have the tank closed. I've never had a problem in any rv i've owned, the Lance included. I also remove the guard on any new grinder I buy. I live on the edge 😁
spectra bash
wash11
Off The Grid
Since you're a new Lance guy, here's a fun read about putting solar on one.
EBT531
worst case, the flame might blow out while driving? I had an RV that had that issue every now and then
I think this is what the danger is...
Pilot goes out, gas stays on, you can guess the rest.
With that being said...
I travel with the gas on as well. 😜
DarkHorseRacing
Just be aware that there are several states where it is illegal to enter a tunnel with the propane on.
New York I believe is one of them.
Not that they would pull you over but they could. Pigs could fly out of your butt too so take it how you want to.
ONE-A-DAY
Do some have fridges that run off of 12v through an inverter? that’s the way our fridge runs in our toyhauler, it’s all electric.
sintax
Post up some pics of the new rig!
I'm still waiting on trying to track down mine... I've been hunting for a reasonably priced Northern Lite 9-6 camper. I'm really trying to avoid buying new, but its looking like I might be.
azsunfun
My pilot will blow out, just precool for travel, I also added 12 volt fan to help blow air across coil helps when it's 107*
USMC2010
My lance fridge had tri power. I left the propane on but typically drive with it on DC, it doesn't cool as well as gas but depending on the drive, sometimes the pilot blows out. Yes you can travel with it on gas.
v6toy4x
Yes, if the pilot goes out the flow is cut, I installed a sniffer on the floor just inside where the bottles are and if it sniffs it kills the LP at the tank connection. Been running TCs for going on 37 years.
TimeBandit
The pilot for the fridge in my Lance would always blow out on the road and for that matter the heater wouldn't work very well either anything on propane was basically a pain in the ass in that thing.
stingray11
Gas off when traveling. Not good to use propane frig when traveling, very dangerous when fueling up on gasoline or diesel, can blow you up. 12 volt frig when traveling.
Ducksquasher
When fueling...my wife clicks the fridge off and I turn the propane off. They both need to be off when fueling. If the fridge's automatic lighter is sparking trying to light on propane and there are gas fumes from the pump...BOOM! Pull away from the pumps and turn them both back on and you are good to go.
timstoy
If your fridge goes out on propane while driving find a furnace filter to fit your compartment door opening and install. I clean my burner assembly yearly and vacuum out the rust and spider webs.
jailbird141
Childs play .... tear the tag off a mattress, now you are living on the edge!
Brian
I travel with it on in my trailer. Never blown out yet or had any issues.
