MerCruiser has decided to make the switch in 2010. The 496 MAG and 496 MAG HO are out of the line-up, replaced by the 8.2L (502 c.i.) block with catalytic converters to comply with the new EPA and CARB exhaust emissions regs.
Wow, I thought the 502 was the old design block from decades ago and siamese cylinder bores. The 496 was the latest and greatest with longevity far beyond the 502/454 block using alum. heads, six bolt mains and complete cylinder flow cooling. Maybe they are doing it to get away from the closed cooling costs that the aluminum heads cause.
496's do not have aluminum heads. From Merc anyway.![]()
I had one from Mercruiser and two from Crusader, both had aluminum heads. That was the reason for the closed cooling on 496s.
Can't say you did not have it. My understanding was Raylar was about the only source.
The two 496's that I had both had iron heads.
Are you sure you did not have a stroked 454 block.
Jeff
This is good news the 8.1 496 is a cheap pile of shit with cast everthing.
Why do you think merc stayed with the 8.2 502 block for HP line.
Dual cats under a closed engine hatch=damn hot:hotdevil:hotdevil:hotdevil
Probably have to install some type of cooling fans too...sounds spendy and heavy:thumbsdown
They are waterjacketed like on the new 496's...
I was asking BB572 about the carb 496's and he was saying you can't put headers on them etc.. Or it'll put the computer in limp mode. Total pain in the ass.
rD
Don't be surprised of the new 502's use similar cast parts to the 496
502 was only produce for crate motors and boats was never in any production cars or trucks. 496 is just gone since there are no big block trucks left.
The 6.0 isn't a "big block". I'm don' t know how to convert liters to inches.......:readpb:
Aren't the blocks different? I thought the 496 was based on the old 427 tall deck truck engines and the 502 was based on the 454 ?
The 496 was an all new design, nothing before was like it. I'm sure GM just simply finds it way too expensive to make this engine for the rec. vehicle market alone since it is not in trucks anymore. Great engine but quite expensive vs. the old Mark series big blocks designed decades ago. Big step back in quality and especially longevity but it is a financial decision. They can build the old style blocks and heads for a fraction of the cost of these 496 engines.
My business manufactures gasket adhesives and non stick gasket coatings for the big three and beyond. All of the automotive manufacturers are now touting the new operating temps of 377F and we are scrambling to develop the coatings. I can't wait to see what that will do to the marine market. Get ready for lots more outboards.
I was actually surprised on the temperature of the exhaust on the C.A.R.B. approved 496. It was warm, but I was able to put my hand on it with no problems. Wasn't noticeably different than a non C.A.R.B. approved 496.
377* --- wow--that is way up there. What is the reason? Cleaner burn at the higher temp?
One liter = 61.0237........... cubic inchesThe 6.0 isn't a "big block". I'm don' t know how to convert liters to inches.......:readpb:
If the 6.0 is exactly 6.0 then you have 366.1424 inches
