Dalton
- Apr 15, 2011
- 2,390
- 2,221
I always took the term crate to mean factory new.
Is it a broader definition now?
Probably close to $40,000 at Teaque, so what gives?720 HP pump gas Marine 632 for $12k. nice!
Teague is in the SoCal bubble!!!Probably close to $40,000 at Teaque, so what gives?
Wouldn't be safer to get a crate engine from Summit? They do free shipping as well.
https://www.summitracing.com/int/parts/mll-ps6320ctc/overview/
Automobile crate engines carry a 30-month or 50,000-mile warranty. Marine Crate engines carry a 12-month warranty.
if you ran a jet boat with bassets ,none of what you said matters much.The ohio crankshaft mill is shown with huge long auto headers on it.
What does it idle at and what kind of vacuum will it pull when you put an in gear load on it at idle?
Dyno starts at 4K- not usually a great sign. whats it make from idle to 4K because your boat has to do that every time it comes on plane.
What does it make wet? and does it revert if the exhaust is underwater at idle for extended periods of time?
UD
UD
if you ran a jet boat with bassets ,none of what you said matters much.![]()
If I were going with something from a crate Id call up the guys at Reher Morrison and have them put something together for me.
UD
In before the pearl clutching. Heaven forbid!
In my opinion the biggest problem with the car crate engines is people using the wrong viscosity oil and the oil not getting it hot enough.
It is an engine, it does not know what it is in. If it is tuned properly with proper oiling, it will likely live a happy life.
Really?
Piston to wall plays a pretty big factor in the marine to automotive applications. (Among other things )
Especially pulling water in from the lake
Get some slick 50 buddy !
Really?
Reher and Morrison built the 510 CI General Motors DRCE (Drag Racing Competition Engine) used in the Spirit of Rett, the AA/FS that beat the 50 year old Land Speed Record held by the Summer's Brother's Goldenrod.
The DRCE was designed by GM engineers specifically for NHRA Pro Stock. Reher and Morrison modified this one for the seven mile long course at Bonneville, running at full throttle for almost one and a quarter minutes on the bottle instead of the naturally aspirated six seconds it was designed for. It produced about 2,300 HP on the dyno.
I was lucky enough to crew on the car for almost a year, converting it from AA/FS configuration to run in A/FS and A/GS. In 2011, I worked on the car from January to August before we went to Speedweeks. It took that much time to get the Liberty air shifted five speed transmission and the massive Winters differential rebuilt, have the engine destroked by R&M, rebuild the brake system, perform some mods to the fiberglass body panels, rework the parachute tube ejection mechanism, add some sensors to the CAN bus and reprogram the RacePak dash, bead blast the wheels and some suspension components for new powdercoat, clean up some salt corrosion and repaint the frame, and dozens of other small projects.
We set new records in A/FS (379.609), and A/GS (353.825). It's pretty cool having SCTA trophies on the shelf with my other racing stuff.
