caribbean20
- Mar 4, 2011
- 1,917
- 4,405
This is embarrassing, but I’m about to go all brute force on this thing. Regular Schlage keyed entry. Spring is loose so handle doesn’t return to position. 23 years old. Merely want to put a new handle on this thing. Instructions say remove the set screw, which I did, and stick a pin in that pin hole to push in a spring and handle should slide off. No go on that. Next drilled out the bastard, still won’t slide off. Not sure if the locking mechanism has anything to do with it but that key is long gone since we use a deadbolt.
Any ideas before I surrender and call the lock guy?
