wsuwrhr
The Masheenest
- Dec 20, 2007
- 35,634
- 23,840
At least the codes makes it clear that you will have to go to the bank, too.
Your truck must be a 02 or earlier, they ditched that AIR system in 2003. The electric air pump is mounted on the passenger side firewall, you can follow the hose from the exhaust manifold over to it. When you first start the truck for the day (cold start) you should feel / hear that electric motor come on. That's the first place to check.
Careful Brian, he's trying to make you put on black lipstickPull the check valve and try to blow through it , if you can’t , replace valve .
Careful Brian, he's trying to make you put on black lipstick![]()
The check valves go bad all the time, if you find a bad one do them both...they are cheap.![]()
I did a lot of check valves back in the day. Moisture in the exhaust rusts them out.Got this code last night. Cleared it and it didnt come back.
Check valve maybe no good?
