Paint vs. Gel
Rajobigguy
School me on boat coatings.
What are the advantages/disadvantages of both?? My understanding is that a good polyurethane paint will look better than gel but is it as durable. Why use one over the other and is one better for some apps then the other??
Apex svt
^^What he said. Had a boat painted by Mitcher T and it was not forgiving if it got into the dock. Instead of scratching it would almost blister apart it chunks. Had a 1x1in piece on the corner pop off, glued it back on for a temp fix. These were taps on the dock, not hard hits.
Reactions: DWC
Rajobigguy
Depends on the paint. My Cigarette was painted with Imron, and that stuff was extremely durable.
"Good thing we don't paint our cars" :rolleyes:
See that's the thing. there are lots of different options with paint. Epoxies or lacquers can be be very hard and brittle but polyurethane can have a pretty tough surface and still be flexible and forgiving.
MK1MOD0
Most east coast hi end boats are painted. Must be something to it.
lebel409
Gel is thick enough that you can sand/buff out most minor scratches. paint is great ( well mostly) for preserving a surface, but not for preserving itself. All the east coast painted boats...are painted on top of gel.
Paint can be more detailed, gel is normally 2-4 colors, Billy B will do you a double rainbow. So on a ocean/fishing/kids/25' plus boat I'd only go with gel, 17' trailer queen, maybe paint.
FreeBird236
This will never be settled, but for the boats that most of us can afford to purchase, gelcoat is a far better choice, much more durable.
RichL
My formula is imron and it seems tough as well, plus I like being able to touch it up easily
Sent from my SM-G981U using Tapatalk
Touching up Imron is something I need to look into.
SOCALCRICKETT
From what I'm hearing imron is getting harder to come by, just like anything else I'm sure there is new epa compliant toner that can be used. I'm lucky in that I don't need any touch up but if I hear of something I'll let you know now
coolchange
Lower level functionary
I’ve painted a couple boats with deltron
( imron). I like it. If you can paint lacquer you can do imron. Hard as eff to color sand if you wait. I would do again if I could get it. Painters say it’s old school and a lot better products out there now.
I used to think you can’t re gel a boat cause I rarely saw one that wasn’t coming apart. But I have seen some lately that are bitchen, we will see.
I just re gelled my bass boat cowls wit the dura tec clear 50/50 and gel coat. Used a 1.4 ( small area) and it sprayed like a urathane. I didn’t wax it and it seems a little softer(good) in sanding. We’ll see when it’s buffed.
Disclaimer coolchange “ not a painter”
Hi jack- I want to clear my glitter boat. Any ideas chime in.
Duramax
When I had my HTM repainted we used Imron. Hard as nails and held up great. My boy who did it at AZ Pro Fiberglass, Scotty, said it is tough to sand and very toxic. That's my very weak 2 cents.
RichL
Appreciate it. The Formula had some dock rash when I bought it and it's always bugged me.
74 spectra20 v-drive
These are all painted... Wood Decker mid 90's, Blue Sanger 92'. Blue Spectra 2013, Purple Spectra 2005 or 6. We have a couple others done in the early 80's that still look great. Good clear, keep them clean and out of the weather and paint will last. Also painting a boat is not like painting a car, that is where people get into trouble and end up with the paint flaking off, bad or incorrect prep, metal is different than glass.
motormonkey
I know paint costs less than gell. I went with gell for durability on my last redo. I've had painted boats that looked amazing.
ToMorrow44
27 Advantage TCM 800efi
I think the main benefit of paint is how detailed you can get with it. I mean, go look at @Skater368 build thread, the detail in the paint is incredible. The Gelcoat is much tougher but more difficult to get a lot of detail in, but companies like DCB, Eliminator, Lavey Craft are able to do some pretty cool stuff with gel.
Skater368
Upon My Request This is all Folks Skater368/nganga
Gelcoater
Yep.
So much more detail and depth in paint. The guy at Skater is an artist in the truest sense.
Steve’s boat is like Picasso level, I’d be afraid to launch it, lol.
Also no way to do in the mold gel work on a Skater, it’s built from scratch.
The right minds and hands in the mix and some pretty amazing stuff is possible in gel.
Our pal Grads previous boat the West Coast Fucker is pretty detailed on a from the mold perspective.
ToMorrow44
Yep.
Wait, Grads owned WCF at one point..!?
DRYHEAT
Yep.
The question I have for you, are any of the boat shops training/teaching younger guys the artistry of in the mold gelcoat? The stuff you guys do do sure has come a long way in the last 30+ years. 😎
Dkahnjob
paint does not hold up well on the parts of the boat that are underwater (below the water line) for a boat that is left in the water for any length of time.
It will blister eventually.
Gelcoater
a lot of 2007-2009 boats had/have similar issue. The clear is super cloudy giving same appearance.
Was about the time Valspar stopped making gelcoat and specifically TX-2 clear.
Gelcoater
I only know of a couple guys coming into it.
ramos45
Unfortunately I know this all too well. I had the aft of my boat repainted when I redid the swim platform. 5 months of being in a slip and the paint at the water line is shit
kurtis500
Theres really no paint that can compare to the bonding between original gel and the laminating resin. The gelcoat on the mold with non air inhibited bonding is second to none. Secondary bonding of gel sprayed on over gel already cured and crosslinked is not as strong..more comparable to paint. Epoxy bonds way better to cured/crosslinked polyester than polyester does. With that said. if you could bring back the old Imron of 25 years ago you have an awesome product. Todays Imron (Axalta) is not the same.
