Boat 405
- Dec 20, 2007
- 4,776
- 8,864
Pros cons?
Pebble Tech, twice the life span.
I’ve heard this. That alone is reason enough to do it imoPebble Tech, twice the life span.
I think we are going with quartz for our build that should be starting in the next month or so.
Build is at Havasu home and Desert Storm is who we went with.Where do you live ? Who is doing the build?
We are looking at doing a remodel, 20 years ago we put in Pebble tech... doing that again. adding a Baja shelf, redoing the deck, repiping the the pool... repipe is because it presently has 2" copper pipe... from 1978. So, we don't want to do the deck and end up with a leak under new concrete..... Looking for bids if anyone knows a good company that will come to Mission Viejo here in the OC.
Thats what we are going with too . Pebble might last twice as long but cost twice as much too . Quartz it is for us but its also our first pool .I think we are going with quartz for our build that should be starting in the next month or so.
We go to MV, let me knowWhere do you live ? Who is doing the build?
Why would a pool contractor tell me the cost is so dramatically more if thats not true ?Twice the life simple as that.
Plaster in 5 years or so will show its age, color plaster usually with in months will look years old
Pebble in 10 years will look damn near the same
Regular pebble, mini pebble, and quartz are all pretty much same cost.
95 out of 100 pools we do mini pebble, 1 or 2 Plaster, and a couple hydrazzo or all glass bead
Im finacialy established just fine thanks but 2 separate pool builder's said it would be roughly 7500 more . I dont see a cost benefit in that .Nothing wrong with quartz, most initial pools are plastered that way if I had to guess. An initial build is expensive, and it softens the blow going with quartz. By the ten year mark and when most people are better established financially, most re-plaster with pebble. My $0.02.
Be careful with quarts. If you go with a color it tends to get blotchy sometimesI think we are going with quartz for our build that should be starting in the next month or so.
Baja shelf’s are nice. We added a tanning ledge which is about 6”-8” of water. Bajas are too deep we think for us. Added bubblers to keep water moving and it looks cool too. Grandkids love itWhere do you live ? Who is doing the build?
Yep our was about that alsoStoneScapes Mini Pebble $2000 more for our build.
A Baja, tanning, shamu shelf or many othe names are all the same thing. Depth is determined by builder/ownerBaja shelf’s are nice. We added a tanning ledge which is about 6”-8” of water. Bajas are too deep we think for us. Added bubblers to keep water moving and it looks cool too. Grandkids love it View attachment 922137 View attachment 922138
No offense meant, just saying if you’re established and only want to re-plaster ONE more time, it was a no brainer for me. Mini pebble is nicer AND will outlive me.Im finacialy established just fine thanks but 2 separate pool builder's said it would be roughly 7500 more . I dont see a cost benefit in that .
Our original plaster lasted 25-26 years before it started falling apart, our current plaster started falling apart after about 10 years. I hit up Grads about it since I could send him pics of the areas and he said it fairly normal of plaster now. He said something changed and it's definitely not as durable as it was in years past, he re-did his and the same shit happened after 10ish years.Why the short expected lifespan of plaster? Our pool didn't start to decay for nearly 27 years. Most of it is still intact after 40 years. Most, not all for sure.
What finish is this?Baja shelf’s are nice. We added a tanning ledge which is about 6”-8” of water. Bajas are too deep we think for us. Added bubblers to keep water moving and it looks cool too. Grandkids love it View attachment 922137 View attachment 922138
It’s the new popular thing. Isn’t anything new, ozone has been around for Pools well over 20 years.Has anyone gone with the ozone system?
No, there’s many people that don’t like the texture. But life expectancy alone makes most get over it.Am I the only one not a fan of pebble tech?
Pebble Sheen both pool and spaWhat finish is this?
Many service guys don’t understand or don’t like salt systems. So they convince owners to do ozone instead.
Yes it works how ever you still need sanitizer ( chlorine ) added to pool. So don’t be talked into that it will replace sanitizer. If doing both salt and ozone. Then all good.
Plaster available today is not the same plaster available from 25 years ago or more. The quality of raw materials are no longer in existence.
So the options are to go with some type of aggregate finish. Just like with concrete typically the larger the aggregate the stronger the material. Plus stones, glass etc... don’t stain, so stains in pools are minimized and or lost in the mix of aggregate and plaster.
If they actually remove down to the pool shell, all good. Doesn’t save any money. Supposed to be easier on pool structure by not removing any top surface. If it’s old style blasting just roughing the surface, pass no buenoWhat about Hydroblasting the old plaster, better removal system or gimmick?
See above, that’s old plaster. The raw materials to duplicate that plaster quality no longer existsSurprised people only getting 5-10 years from a plaster pool? My old plaster pool was 22 years old when I sold that house and it was like new and I never touched it.
