Polishing up the Ranger..
As most know I broke an upper A arm bolt on the Topock ride. Well instead of just replacing the bolt, ball joint and moving on with life I decided to clean up the Ranger a bit!
Took all the arms off and sent them out for Powdercoat! Should be done Monday. :). Having them done in a tougher textured finish called “silver vein”. Black with silver veins running through the crevices.
Also ordering new brake pads, and all new (stronger) bolts from the bolt nazi!
Wheeler
Did you have the workbench gel coated to match your Schiada?
What lift is that?
It's the SUPER ATV Lift and then Barker modified it slightly to accept the King shocks. I made the little spacers etc.. to accept the limit straps so it won't tear the CV boots and go through axles etc..
