Prop Shaft Question
420HOA
FIRM MEMBER
21' Howard v-drive 29% C-500, blown 532 950hp 1" prop shaft. I have to replace this shaft, I'm thinking Aquamet 22.
Any input ? :cool:
Hallett
That would be a good choice . that's pretty respectful hp out of a 532
how much boost.?
dimarco
keep the 1 in shaft . put a three blade prop and a wake board tower on and have fun with your family boat,( it will never be fast) kinda like building a blown station wagon.
420HOA
FIRM MEMBER
Who hurt you Dennis ? Your just jealous cause you never been Blown in a station wagon. Stick to things you know, not things you BLOW !:rotflmao:
420HOA
FIRM MEMBER
how much boost.?
That was peak hp on dyno on pump gas with 8lbs boost.
I only ask about the Aquamet because I have never used one,. I just put a K manel shaft in my Schiada but thats way more hp and was crazy $. Aquamet 22 is less than half of K manel.:grumble:
Hallett
Thank you I am thinking about changing mine now before my new motor is in
I have the Aquamet -22 in mine now . I will probably put the same back in .
still looking into it. thanks for the info.
djunkie
Broke mo fo
So what do these new prop shafts cost? I'm thinking of putting new one in mine while its apart.
You currently can't get good K-Monel, the good stuff used to come from Canada but since we have outsourced nearly all of our founding industry the K-Monel now comes from Italy, and as far as i'm concerned it's pure junk, i don't know if they are having a problem with their hardening process or if it's just the physical blend they are using, we got a piece that measured only C28 hardness on the Rockwell tester, it should be about C34-C36. We put one on a customers boat and the shaft bent and it cost the customer about $5k to reset the strut, do some glasswork, and put an Aquamet 22 shaft in it. Aquamet-22 rockwell's out to about C35 and has seemed to hold up pretty well.
The good old K-Monel shafts we liked better than the aquamet, they seemed to hold up to wear better at the strut... but the current ones are shit, go aquamet.
I can quote you on one and order it for you if you give me the length...
Rexone
an ordinary American
If anyone is in need of Aq22 x 1 1/8 diameter give me a shout. I am overstocked and would like to get rid of a few for winter. :rolleyes:
I have 14 ft double ended lengths and cut and key or just cut, to order.
1" I can't currently help on, out of stock for the moment.
420HOA
FIRM MEMBER
Hey, the shaft that was in it when you got it was a k-monel. what up?K-B it tough on equipment!:rolleyes:
Its back in it and the vibration was the rudder bearing and the PROP. Got it back from Wilmington Prop today, 1/4 out. It may go faster now !:moon:
Sawtooth
Thanks for everything Dad
Hey Mike is the offer on the 1 1/8" material still good, I may just have to buy myself a Christmas present, can you PM me what it runs a inch or foot or however it is sold Thanks.
420HOA
FIRM MEMBER
What material should the 1/4" key at the prop be made of ? What about the coupler to V-drive, should that be case hardened ?
I ask because when I picked up my newly ballanced props they handed me brass key ways. That seems very soft for high HP. Any suggestions ?:blah:
The taper is what holds the prop from turning, the key is basically there just for reverse, and to stop it from initially turning. Once you run the boat the first time that prop has pressed itself pretty hard up the taper, every ounce of forward thrust the boat gets is because that prop is trying to drive itself up the shaft. the key itself doesn't have to be that hard on the prop end, we use standard, non hardened, stainless key stock and have never had a problem, just make sure you grind and shape your key so that the prop is all the way seated on the taper.
If you notice whenever you pull a prop how freaking hard the thing is stuck on the taper, and it's almost never hung up and bound on the key itself. most times the key is loose and you can slide it inside the groove with a pick or small screwdriver while the prop is still on.
420HOA
FIRM MEMBER
Thats the knowledge I wanted to hear now what about the other end of the shaft ?:thumbsup
If you fit the key properly, nice reference fit, and your split coupler is properly sized to the shaft stainless keys work there as well. That's what we've always used, never had a problem.... Even on big hp turbo stuff
Some guys say use craftsmen standard screwdriver shafts, which are good hardened material, but they will rust, we've never bothered because we've never had issues with the stainless keys. We buy keystock from McMaster for these applications. 316 alloy.
420HOA
FIRM MEMBER
This ones in a C-500 its just coupler to coupler. Thats why I ? its strength.:blah:
You mean a 4 bolt companion flange instead of a split (pinch) coupler??
420HOA
FIRM MEMBER
I knew you had a tech term for it. Ya that one, 4 on 4 !:grumble:
