replacing a retractable stern light on a magic.
adam909
My electric self retractable stern light just stopped working on my magic deck boat.. Its stuck about half way and won't go down.. My research shows that they do not make them any more. I found a manual stern light that retracts that looks almost the same by innovative light. Im sure I'm not the only one that has this issue. What has everyone used to replace there worn out retractable stern light on there magics.
wet hull
Mine used to do the same thing. It was do to bugs getting wedged in between each section. I cleaned it and has worked ever since.
Reactions: Wmc
El Chingon
I have the innovative light electric one too on my magic, bought it from Eddie marine. Have had it for about 7 years with no problems. Just have broken the lens once and bought a replacement from inmovative direct for about $10.
Havasu Catman
You are right they don't make them anymore. The only practical option is to replace it with the manual one or fix your old one. The hole size that is in the boat is so big nothing else will work.
prosthogod
I took the motor off the old one and put new shaft from manual one. Works like new
I would replace it with a standard stick light. There is a new product coming on the market in the next month or so. I'm pretty sure everybody is going to replacing their traditional stearn lights with these things when they see them.
Riverbound
More details please. As this right now I'm not putting a stern light back on the stoker due to cosmetic reasons. If there's something that looks good then I will.
The guy brought me one of the prototypes for my Schiada.. But he told me I couldn't release any details until he says it's alright.
Enen
Let's be honest. Your Stoker isn't coming off the trailer any more than a Schiada now. It's in no danger of seeing a sunset. :D
Riverbound
I can't agree more. I doubt the boat will ever see a night cruise again. I should have shaved off the red and green lights at the time we were having everything done.
The last time we took it out at night almost ran into a boat floating with no lights on. Since that close call, I really don't do any night boating anymore. Just not worth it, with all the idiots I see with no lights on [emoji107]
Kachina26
Inmate #RDP158
Is it alright yet? Mine just took a dump last week. Was it from "Safety Whips"?
@RiverDave
Guest06
I stumbled across a couple of these power stern lights brand new in box. Will have them Friday it looks like. Being it looks to be the last of the last i paid a serious premium but figured screw it i can sell a couple or just keep them in the cupboard. If interested hit me up.
Englewood
Interested...Let me know a price.
This was about the time the boatwhips were just coming out!
Shlbyntro
Ultra Conservative
Does anyone still have their broken powered retractable they'd be willing to part with? I had a customer give me his that I fixed to put on the Ultra but am reluctant to drill the hole for it unless I have a spare in the event of a failure that I can't fix. Multiples would be even better
Please let me know. Thx
wet hull
Never had issues with mine other then plastic lens always comes off no matter what I do. I keep a box of spares.
Shlbyntro
Ultra Conservative
I had a broken retractor cable in the one I just acquired. I removed the broken section but am worried it could happen again being it is a 15yr old unit. I want a spare to have on hand if my current one ever breaks. To my knowledge, there is nothing out there that will fit the hole this thing requires and I would hate to have that hole in my boat if this sucker ever fails and I can't repair it
Guest06
The manual one is same size, prior to scoring on the new one i have, i was looking around and was planning to go Boat Whip or whatever they are called full plexiglass tube with leds. Was just going to use a polished bezel at the base plate.
Erod1738
New Member
I just purchased a magic from a friend, the retractable light not working. I removed it gonna install the polished bezel plate from safeglo whips and install standard light connector. Its yours if you want it. PM me if interested.
Mwrenx3
New Member
Mwrenx3
New Member
Do you still have new stern lights in the box ? Text me 314 6516400 plz
nordic454
WWW.METALWORXLV.COM
Mine stopped working on my Force too. It won’t go up, and the lense is missing.
Maestro
Interested
Texas252Tte
New Member
MY motor housing separated from the shaft. When the light was turned on things went really bad. All apart now. Plastic cable is broken 5 inches from the end but the inside wire is still connected. Did you cut the broken pies off, strip a little more for the wire and then solder it at the other end of the light shaft? I haven't taken my shaft out and apart yet to see what the connection point looks like. How does the motor know when to stop retracting? If you would like, perhaps you could repair my assembly for a price. Or I can pay you for the instructions and advice. Thanks.
Shlbyntro
Ultra Conservative
I had to cut off the end of the plastic gear wire that were broken and do some soldering. As far as when it knows to stop, its just a very simple load sensing circuit that's built in to the whole unit, as soon as it senses any kind of extra resistance it'll trigger an internal switch that stops the motor. It did require disassembling the unit and removing the broken piece of wire and then soldering the bulb figure back to the end of the cable as well as drilling with some set screws and epoxy to hold the shaft/housing together. I ultimately lost about 18" of travel on mine when I did it.
There's some pics in my Ultra thread
Good Stuff
Hey Dave,
When are these going to be released?
thanks
They have been out for a long time. This thread is pretty old. The adapter is pretty clean. I had to use it to replace my electric extending light.
