BUSTI
- Mar 24, 2010
- 2,041
- 817
First some insight on set up. The engine is a 460" BBC with iron 088 cylinder heads and polished chambers. The bottom end is pretty decent for what it is. Kellogg crank, Manley rods and JE 7.9:1 compression. With a non intercooled 250 B&M supercharger. Dual 750 Holley carbs. When it was built it was considered a 600 HP build. I'm sure it was. The engine runs very strong and is a lot of fun. I'm not looking to increase power but the blower does look a little small. I'd like to upgrade to an 8-71 Blower Shop Billet supercharger. It looks so cool and I'd like to have a little wow factor then I open the engine hatch.
So the question is if I up grade to the 8-71 and stick with the same 6psi of boost what effects will it have on the engine? Will it generate more heat? Will it need to go back on the dyno? Will I loos a lot of power due to the increased supercharger size?
Thanks for all the help.
