Ibeplumbing
- Feb 2, 2013
- 1,570
- 978
IF you post a closer pic of the rubrail Shueman can probably get it for you. It looks like my rubrail and he quoted me $100 per 10 foot stick.
Break out the Magic eraser. Wowser!
I purchased a "roll" (not sure how many feet) of similar rub-rail for my Warlock from Advantage, they had it in stock. It may not be completely identical to yours, but close enough that you can switch over to it and it will probably look the same if you did all of it. Its is just white plastic. I have lots of tight bends as well, I currently need to replace the section on the nose, between the sponsons, from pulling onto the trailer a bit to "hot" and bumping the bunks, which cracked a section.
I'd love to switch to a nice stainless rub rail, but im sure the cost ain't cheap
I'm replacing my rub rail on my warlock 25ft sxt, from what I have been told the original style one is gone, can't get it. So I was thinking of doing a stainless insert style. Can a stainless insert style work on my front end? It has a ton of 90 bends on it
