Braggin Rights
- Sep 23, 2018
- 16
- 9
2005 Howard 25’ Bullet
This boat has been babied and stored indoors since day one! Boat is near flawless in and out. Howard Custom boats in Southern CA makes this stepped Hull 25’ Bullet. Howard Custom Boats is arguably one of the best made boats that you can buy! Has 496 HO Motor upgraded with Dana Headers and Raylar engine upgrade. This engine was sent to Raylar and rebuilt from the ground up with Raylar Big Power Heads, cam and intake manifold and ran on a Dyno at 588 Horse Power. Also Custom Wet tested and tuned by Carl Summers. Also added Aeromotive High Pressure Fuel System. 28 pitch Stainless Steel Prop. Mercury Racing Bravo XR Drive. Performance Dual Piston Imco Hydraulic Steering. Hydraulic Dana HP900 Trim Tabs.
I have upgraded this Bullet with over $10k JL Audio Sound system. JL Audio Speakers, Subwoofers and Amps. Marine Alpine deck with remotes, It ROCKS!! Also upgraded to 3 Optima Blue top Batteries with a battery isolator so when you are parked you can run the stereo and accessories off the 2 accessory batteries and it will still start off the starting battery every time.
Below the closed bow there is an oversized bed with some storage under cushions and 2 seats, a cabinet for the stereo & storage and a built in cooler that drains out of the boat.
New Bellows 90 hours ago. Has been perfectly maintained. This is an 85 mph boat that is completely turn key. Starts right up every time. This is a hot Rod but not one you will spend your weekends wrenching on to run right, I carry no tools and don’t need them.
Trailer is an Ellis Tandem Axel Trailer made for this boat. I have added custom 17” alloy wheels with the correct load rating low profile tires. I have also upgraded all the trailer lights to LED Lights with custom made bezels. 4 Wheel disc brakes and torsion bar suspension and breakaway tongue to make the trailer shorter. I have had a few boats and trailered many and this boat on this trailer trails the best of any of them.
Has stainless steel Bimini top and snap on cockpit cover, dust cover and garage cover. I like my equipment well protected.
If you are looking for a Hot Boat that looks like an Off Shore Race Boat, Sounds like a Hot Rod, Accelerates and Handles like a corvette, Runs with the Big Boys and you get compliments and turn heads every time you take it out. This is the boat for you! This boat needs nothing! The Boat also has an AZ Title. If you don’t understand the benefits of that, just ask me. $48k obo. Call or text Mike 510-541-8481
