Blueduck
- Feb 20, 2008
- 160
- 79
Title says it all....Just picked up a smoker and not sure how to smoke a TRI TIP......Thans for the suggestions
That sounds good.....I also read that after pulling from smoker....to sear it on a grill then pull it and wrap it?? Have you tried that method...Thanks
Tri Tip is very tender even when it is cooked at high heat (unlike brisket) so as long as you don't overcook it it will be great.
That is what I just picked up...the Treagar Texas Smoker.....I will be smoking this weekend...Thanks
Gotta love the Traeger! It's the RonCo of Smokers....just set it and forget it!
You can go to Traeger.com and go to their recipes/instructions for more info
Tri Tip turned out pretty good.....thanks for all the info.
I also did baby back ribs a different day....i used the 3-2-1 method and was not really happy with how they turned out....no where near a fall of the bone....any suggestions for ribs? Thanks
IMHO, the best ribs are the ones that DON'T fall off the bone......
P.S. I just noticed that you are at Hidden Shores. What spot are you on? I was at HS for almost 16 years and still have a park model for sale there (A60).
Everything you will ever need to know about smoking ribs right here. The only thing I do different is I smoke at 275* not the 225* he recommends. Play around with the smoker temp until you find what you like.
http://amazingribs.com/recipes/porknography/best_BBQ_ribs_ever.html
I have tried that method... the secret is to leave them on for longer or a higher temperature until they "pull back" on the bone. You need the temp to carmelize the meat. I left mine on for 1 hour longer and then the magic happened.Tri Tip turned out pretty good.....thanks for all the info.
