Source trailer rub rail insert?
Looking to buy a couple hundred feet of this in white
SOCALCRICKETT
If I'm not mistaken taco marine makes that along with the heavier stuff for marine applications. I have bought taco molding from great lakes skipper in the past with good results
Sent from my SM-G981U using Tapatalk
paradise
Spooner
SOD
I looked all over online for the same trim. Ended up stumbling on a roll in the RV section at Spankeys about a year ago.
boatpi
It is rv based. We actually supply a distributor in Cali With the aluminum base molding in various colors plus slide out caps. Their business is way up since Covid.
RD, try to get USA made, Some of the Chinese cheap stuff does not have enough aluminum oxide, that’s the ingredient that keeps it from cracking turning color.
Didn't that's what caused the problem. The sun will tan the cheaper stuff, and then it gets brittle. On install, I've found letting it bake in the truck helps (normal temps, not Havasu in August...) I use narrow plastic scrappers, 1/2" or so to push in the second side. Screw drivers may leave "teeth" marks.
LazyLavey
See Getch above..... or Any rv shop.... "insert molding", "screw cover"
Cheap stuff
