evantwheeler
- Dec 27, 2015
- 3,193
- 6,403
I have a '77 toyota landcruiser FJ40 that has an older 327/350 with an early Howell/Edlebrock fuel injection kit on it. I just started having an issue where the vehicle will run without issue until it gets to operating temperature, sometimes it runs for a half hour at operating temperature, and then it starts sputtering and dies. Cranks, cranks, cranks, no start. Let it sit for a half hour and it fires right up and I can drive for about 400 yards and then it dies again. I've checked fuel pressure and fuel isn't an issue. I read last night on another forum about someone having an ignition/spark issue only when the vehicle got up to operating temp. This site has a vast wealth of knowledge, so figured I'd post here and see what input I could get.
I've replaced the ignition module inside the distributor, the cap, the rotor, and the coil. Other than the distributor itself and the ecu, not sure what else I could replace that controls the spark. This issue is definitely temperature related and affects spark to all cylinders, not just one or a coupe. The temperature comment is not to say the engine is running hot at all, it certainly is not, but once things warm up, it seems that I am losing all spark somehow.
Any input on where to look to try and resolve?
