TRX 70 won't start
Tio Pancho
I have a 1986 TRX 70 I am working on for my grandson. It ran about a year ago. I just rebuilt the carb, changed the run/kill switch. Confirmed fuel flow into the carb bow and verified spark. Won't start even with spray.
I am stumped. Any advice?
Thanks
Frank
Meaney77
Buy a new carb, they are cheap.
I just went through the same thing on a JR 50 I bought as a Christmas gift. Buy the OEM- dont wast your time or money on the cheap Chinese version from Amazon. I pulled the cheap one apart, cleaned, adjusted, etc.. very temperamental. Ordered a new OEM carb and it was delivered the next day. Slapped it on and it was running like a rapped ape within about 15 minutes.
Tio Pancho
May do that. Just found a place that sells only ATC and TRX 70 parts.
Thanks
Tio Pancho
Didn't check it but hand over plug hole felt good. I will check it out today though. Thanks
wsuwrhr
The Masheenest
I have an 86 TRX70 for my girls I bought when the first one was still in the womb.
Tio Pancho
These things are awesome. We have had this one about 15 years. Got it for 300 bucks from a friend. Hardly even touched it except for basic maintenance.
Gelcoater
Thanks
Frank
Try bypassing the “new” off/run switch, and ensure it’s wired correctly and working. Double check your ground.
wsuwrhr
The Masheenest
Which is what IMA thinkin. He said he has spark though......
These fuckin motors aren't that smart. a little fuel, some spark....out to at least "pop"
outboard_256
aside from compression also check the clutch. If I remember right the kickstarter/pull starter goes through the tranny side and through the clutch before it gets to the crank. If the clutch is slipping the crank isn't moving or moving slower than needed it could prevent it from starting. You will feel it slipping if it does as you can't feel the 4-strokes. Other extreme possible causes, bent valve, loose timing gear bolts, timing skipped a tooth, woodruff key sheared, CDI box (or points)/spark plug not producing big enough spark, warn rings, cracked cylinder. Doubt its any of these if it was running fine when you last used it though. I used to build/race 50's so I went through a lot of engines.
Tio Pancho
Fuel, Air and Spark. Shouldn't be this hard. But like my dad used to say - It's the 3% rule. You need to be 3% smarter than the object you are working with.
I will double check the kill switch. But I would think if it was bad I would have no spark.
wsuwrhr
The Masheenest
Yep. I say the same.
"You got to be smarter than what you are workin on."
wsuwrhr
The Masheenest
Are you sure it has spark? I mean, if you are spraying starting fluid in there and there is spark. It should at least pop.
Is there a beetle that made a home in the bore of the carb?
Tio Pancho
I pulled the plug, closed the garage door and turned off the lights to check spark (at night). There is spark. I sprayed starting fluid into the air cleaner. I just dont get it.
I am leaning towards a timing issue.
Gelcoater
Pretty sure those engines run a points ignition for what it may be worth.
You put a gauge to it to check what kind of compression it has?
