Rbcconst
- Nov 20, 2016
- 1,784
- 1,155
Had a referral to have my 502 re built at Wayne's in riverside. Any seconds to that or disagreements?
If you're putting it in a pickup truck, that's going to auction, that's a good way to go.
They are the walmart of engine rebuilding. There is nothing performance or racing application related about them. They sell very generic engines for a very cheap price.
I read about; "fresh heads, good compression readings, ran good for a while, then oil leaks and rough running" .
How do you know it's blown up, were more tests (leak down?) done ?
Do you know WHY the oil is not returning back to the oil pan ?
When you backfire a Holley carb, the power valve (s) may be damaged and cause, rough idle, poor top RPMs, Gasoline odor, and dilution of the engine oil .
You may also have a leaking mechanical fuel pump, that is dumping raw fuel into the oil and filling the crankcase .
Just a few thoughts as I await your reply .
P.S. have an 'A' frame in Havasu that removes motors easily ............
There is nothing like hitting the key at the ramp and nothing happening, or being out on the lake, with a broke prop turner and coming home on a rope.
There are several peeps on this board more than qualified to do your motorwork.
Better to pay once and have no headaches.
Boat motors are finicky animals, and take a little more time to prep than a motor in a car, if you don't want issues.
B&D marine, Obnoxious are two peeps that immediately come to my mind. I think Rivermobster is still doing motors as well.
Brian
Barry. Obnoxious Racing
