What is involved with installing a good train horn?
GRADS
Let's just say I had a car that I wanted install a train horn on....what does it take? A compressor? Just curious.
Go onto hornblasters.com I would not be surprised if there are pictures of a dumbass car.... Err.... I mean Smart car with a full horn set-up on there. I've seen some crazy installs on that site
They just need a lot of hot air, so yours should work well. :D
The previous owner had one on my Dodge but I took it off because I never used it. There were only a few wires going to it which I just cut, then threw the thing in the trash. That's all I've got my friend. ;)
spectras only
I had a real train horn off of a diesel locomotive. Gave it to a friend who had a WWII 72' mine sweeper converted to pleasure cruiser. You'd need a compressor capable of continuous 120 PSI. Horn from a decommissioned ferry would be the real cat's meow though:D
Guest06
You’ll never get a true train horn sound.... 1.25” id air lines, at a constant 120psi with volume that will never end.
COCA COLA COWBOY
At least a 3 gallon tank
Horn
Switch
Relay
Compressor
Three colors of wires
Fuse block.
I can make you a parts list if you like. You can buy a lot on hornblowers.com too.
Mike K
i want one of these so bad ... I’d mount it right rear underneath ... so when I’m following someone weaving and going 3mph cuz and basically holding everyone up cuz they’re texting I could blast ‘em when I drove around them ! Scare the crap outta them . Haha .
sintax
Is this some new technique the gay guys are using to attract dudes while cruising? Figured you'd pull plenty of pole as is simply driving that thing around.
Shlbyntro
Ultra Conservative
Just park that baby at a railroad crossing and wait for a freight train to come by. The freight train will actually drive through the smart car without hitting it because its afraid of its smartness. When it's done passing, the horn will be installed and ready to go.
Ive installed a couple...
On a full size truck, you have to relocate the spare tire...
You're better off buying one of those hand held air horns for That car! :D
Not always. If you break up the set-up you can mount almost all the components on the outside of the frame rails and such. I've helped a few buddies do theirs like that
Train horn installation is orders of magnitude more involved than installing a front license plate on a benz...you'll definitely need to see your mechanic for this one.
LowRiver2
Can’t go wrong with Nathan’s
Around $1800
ElAzul
Well-Known RDP Inmate #211
I have installed a handful of them not that hard just need to find the space
j21black
Just get your purse out and pay someone to do it, like you did with your front license plate holder.
Uncle Dave
3 components to auto train horn performance.
It's pretty much a more is better type of deal.
air compressor CFM - the more the better
Air storage in terms of how long can you deliver X CFM - the more the better
trumpet count and tone - the more the better.
UD
