Kyle Kerby
Hey everyone,
Sorry if it's a dumb question or has been answered (I searched but didn't find anything). I've got a '71 Schiada flat bottom I inherited from my old man. I'm getting her back on the water and will have the engine done this month, but had a "creature comfort" question. The torque tube was always a limiting factor in rear seat width on this boat when I was a kid, and I was wondering if there is a way to use a solid driveshaft, thus being able to reduce the tube by probably half so I can add a few inches to seat width in the back. I'd like to enclose the tube with a center upholstery down to the floor to keep feet and other things away from the prop shaft coupler. Obviously with the v drive (Casale) and motor being fixed to the stringers there's not really any need for U Joints (provided that engine to v drive alignment is correct) but I can't find anything about this anywhere. Anyone have any suggestions where I can find some info on doing this? Or if there's a reason not to that I'm overlooking? It'll be somewhere between 500-500hp so nothing wild that a good driveshaft won't work for. I pit crew on a blown alcohol nostalgia drag car that's 2000+hp and we run a solid driveshaft so that's where I got the idea. Anyway, let me know if anyone has any thoughts or experience here, thanks!
Hey everyone,
Solid drivelines on flattys are pretty comon. You should post this in the V-drive section. It will get more responses.
Yes it’s possible but…
The center line of the crank must hit the center of the v drive, and the flywheel and v drive input shaft must be parallel. +\- a degree. Probably not happening with the older v box.
Build a wider seat.
There's a few guys using a sprint car type driveline with U joints and a splined axle deal. That could work for you but it isn't a cheap alternative. Our old Schiada flat had the standard driveshaft with a back to back bench in it with hump built in for the driveline cover
Back
