2FORCEFULL
- Jan 26, 2008
- 28,745
- 16,978
all I did was fix divider, and remove the stock griles....(ducted ac)
I think I remember you posting these upgrades before, can you link to the post or repost what needs to be done? I need to get my new fiver fully 2FF approved. Any other tidbits or things to do or add that we can use to improve our trailers?all I did was fix divider, and remove the stock griles....(ducted ac)
you could have found this years ago right here... i've been doing this mod for years... you can do it with a piece of sheet metal and get the same results...I found d this on another forum I follow and plan to do it to mine soon as I have time.
Seneca A/C Airflow mods - Jayco RV Owners Forum
After seeing a YouTube video of a new product from RVAirflow to improve the AC/Heat Pump efficiency, I opened mine up on our Seneca and was shocked (well not really) at the the quality of the factorywww.jaycoowners.com
I cheeted a little.... my coach has metal ducts encased in foam... I took a reading from the sheet metal... it's my thought that those long metal ducts that are ice cold will sure help the little AC's to be wat more efficient35 degree supply temp means you have a 20-30 degree coil……That’s not a good thing. As the coil is below freezing temp and will eventually ice up.normal supply temps should be in the 40-50s or in the 15-20 degree drop from return temps.
I have considered doing this mod to my units as you have posted about it a few times.
here's a question for you as you are a professional in the trade.... don't ac units have a set requirement for sq in of service and return???? on my home builds I put return air in all the rooms... my homes you can't hear the air and hve no dead spots, cool down quicker even with bedroom doors closed..35 degree supply temp means you have a 20-30 degree coil……That’s not a good thing. As the coil is below freezing temp and will eventually ice up.normal supply temps should be in the 40-50s or in the 15-20 degree drop from return temps.
Yes you want to achieve 400cfm/ton. To figure out air flow of a register take length x width x 2.8
Example. A 10x30 grill will flow 840cfm. And that’s good for up to a 2 ton unit.
You really can’t oversized return air but supply air will have issues if not properly sized. Too big is as bad as too small.
so doing math.... 1 ton = 12000 btu,.... a 13.5 btu is about 1.1 o1.2 tons.... a 32 x 10 is only 320 sq ft.... so a single unit should cool... but that leave out sun load for windows and such..... a single unit rv will cool at night.... but not during the day... so my theory is the way to get the most out of a unit is to get max air flow across the evap......????Now to figure out the cfm needed per room.
It’s length x width for a standard 8’ ceiling.
So a 10x10 room is 140cfm.
For ceiling heights above 8’ you multiply
1.1 9’
1.2 10’
Etc etc.
To a point yes. But too much air across the coil doesn’t allow for proper heat absorption by the coil. Refrigeration is a cycle And all parts of this must be correct. Too much and too little of one thing will negatively affect the performance.so doing math.... 1 ton = 12000 btu,.... a 13.5 btu is about 1.1 o1.2 tons.... a 32 x 10 is only 320 sq ft.... so a single unit should cool... but that leave out sun load for windows and such..... a single unit rv will cool at night.... but not during the day... so my theory is the way to get the most out of a unit is to get max air flow across the evap......????
have you looked inside a rv ac????? nothing they do makes senseTo a point yes. But too much air across the coil doesn’t allow for proper heat absorption by the coil. Refrigeration is a cycle And all parts of this must be correct. Too much and too little of one thing will negatively affect the performance.
But like i stated above.near impossible to have too much return (air entering).
watch the video on post #4Just got a 2022 A, 2 roof units. I’m having a hard time understanding the mods - would LOVE to see 2FF do a video. Steve, can you do a “list”, step by step - I might be able to follow that and get mine performing correctly
I looked at that option but couldn't see paying $170 for a piece of styrofoam so I followed what this guys did. I also noticed the the registers were leaking bad due to them not being taped well to the ducting. made a huge difference in cooling and db level.I tried the tape last year it did help but I was still losing air. This year I bought this styrofoam pc from these guys and it made a huge difference. I did lose the dump air future but the trailer is much colder. Waiting to see how it does when it gets really hot out here in Havasu but even at 100 outside it’s been real cold inside. Might want to check these guys out…
RV Airflow Systems
Improve the performance of your RV air conditioner! Our system increases you’re A/C’s cooling by maximizing its transfer efficiency! EFFICENCY IS EVERYTHING! Cooling down your RV faster, Quieter, and more Comfortable! Coleman, Dometic, Furrion, & GE Air Conditioners ( Grand Design, Thor, Forest...rvairflow.com
