Custom rzr Cage Build
Hammer
Well I finally had a Chance to get started on my rzr build. Dropped it off and already mocked it up. Still need to fine tune the roof height.
Plan is cage,roof, roof rack and a few one off things I have up my sleeve.
Thanks to Safeglow whips he set me up with a light bar, dome lights and lighted whip mounts.
Anyone able to measure their roof height for me from the top hinge of the door?
I need reference points for my build. Going after a dual sport look similar to below IMG_3984.jpg IMG_4616.jpg
The radius cages look cool, but I don't like the lack of headroom most have in the back. The flat roof will make the roof rack really functional! looking forward to how the home grown turns out!
Hammer
I'm staying away from the radius cage. Flat roof very similar to the cognito cage. IMG_2505.jpg
plaster dave
Face down A$$ up
Mike I would put a little curve in the roof. The axia has just a slight curve so it's not straight flat.
I love my roof rack. I got chairs up on it right now.
Hammer
Any more pics of yours? Also, how tall is your roof?
Groper
Mike,
Before you get just some random Int. height from someone, make sure while sitting in your mounted seat that you have plenty of clearance between your head with a Helmet on and the roof.
Several cages out there are low profile for that "cool look" without any accommodations while wearing a Helmet also aftermarket seats have more padding which sits you higher, carry on ;)
Hammer
Mike,
Noted. We mocked a roof height at 27" from upper door hinge. I sat in a buddy's rzr with the same seats I am going with and took some measurements off of his cage to get an idea for roof height with plenty of head clearance. I'm on hold before final assembly, going to purchase the seats first.
I'd like to lower the roof height to around 24" from upper door hinge. The final height is still pending
When looking into fabricating my own doors it will be quite the undertaking so I am now looking into pre fabricated doors that I can purchase and bolt on.
Two things I'd like to do and need to research
. 1. Get rid of the B pillar all together and weld my own door tabs on.
2. Get a layout of where these tabs need to be.
One solution I ran into is going with TMW's Door kit that comes with the hardware. I believe the door "lines" make the look of the car. It appears these are a bolt on kit. I also have an admiration for their work.
This would solve setting tab Heights on the b pillar.. (I think)
http://www.shop.tmwoffroad.com/product.sc?productId=853&categoryId=106
plaster dave
Face down A$$ up
A lot of guys use the stock rzr door latches as their the best.
Shortdeck
Are you building the cage and rear bumper as one piece like the Axia car? Looks good so far.
Also did you leave the windshield low for the light bar?
Hammer
More pics.
Shout out to Devious Motorsports on the hook up. Just ordered seats for my build.
Going to look something like this with a bench in the rear
Devious_Chris
I wear sunglasses, lake Havasu city az.
Hammer
I'm not going to integrate the cage into the rear bumper like the Axia Car. I have plans for the bed area.
Yes the cross bar is low for the light bar.
Shortdeck
Are you doing a windshield? If so, take pics please.
Those seats are bad ass!!
Hammer
Thanks! We added seat heaters in the bench and front seats.
Rear bench
Yes we are doing a windshield. Will put tabs in for "future"
Cole Trickle
It doesn't look bad but it doesn't look like it was built for the rzr. Needs to go forward about 10" to mount a light bar and then the back would look better if it angled. IMG_9194.jpg
You can see what I'm talking about on the rack I designed for my dads jeep.
Hammer
It doesn't look bad but it doesn't look like it was built for the rzr. Needs to go forward about 10" to mount a light bar and then the back would look better if it angled. View attachment 534265
I agree. But it will be removable so I won't incorporate the light bar
plaster dave
Face down A$$ up
I agree it needs to be longer. The sides look cool but make sure you have tabs for the tie downs up there.
JBS
The rack that made it top heavy so it tipped over ;)
jesco
Mine is removable and my light is incorporated. Once that rack is installed you want remove it. Trust me. [emoji16]
^^^ THIS... I had a rack on my last RZR, wanted to make sure it would come off easy... NEVER even thought about taking it off once I got the car. Make it as big as possible without looking ridiculous of course. They are very functional, but remember, these cars don't like weight up high so don't over load it.
Hammer
Lookin good Mike! I'd make that rack full length so its as functional as possible. Always liked the lines of the Magnum rack...
Out of all the cars I looked at magnums the most. I don't spend a lot of time in the dunes anymore. I wanted more of a dual sport look that was functional.
jesco
BADASS CAR!!!! Magnum builds really nice stuff
Hammer
Another AWESOME car!!! Magnum and Cognito pull off the flat roof VERY well, best two on the market in my opinion.
Completely Agree!!! Those are the ones I spent most looking at.
Strabo
Now ya need a better clutch. They aren't cheap.
