F26 / Mach 26
JFMFG
i took apart the upper and steering cap. Didn’t see anything wrong. No metal shavings or pits in the gear.
I also did get a quote for the Scx and trying to make it happen. Only problem is I need to take off my extension box and helmet to be powdercoated.
Rich people problems.
Nail It
You wouldn't be able to see much with the caps off if the clutch shaft broke. Did the drive go into nuetral when it broke?
When you took the lower off could you spin the drive shaft and/or prop shaft? I've eaten quite a few lower gear sets and there was alot of metal on the plug magnet. Your magnet looked like it only had a small amount of metal from the picture.
ChrisV
It stayed in forward and free reved.
I could spin the lower unit. Didn't seem like it lost a gear but it did make a clicking noise spinning.
The lower is getting torn apart in the next few hours so hopefully we find nothing. But it does make me wonder what cause the shaft to break? Last week i did jump a wakeboat wave pretty bad and was on throttle.
Nail It
The lower gears will make some noise when the lower is not bolted to the upper, since there is no preload on the pinion gear.
Jumping wakes while on throttle is exactly what will break clutch shafts. This is how I broke my first XR in 20 hours, the other 2 lasted 40 hours, and the SCX upper has 250hours and counting. My driving style has not changed.
All 3 times I have broken an upper is when getting on plane. I try to keep it under 3k rpms and once it rolls over it's game on. Everyone says you need to be easy on it, but who buys a mach 26 to baby it and drive 30 mph everywhere? Not me!
I'm willing to bet your issue is in the upper. But let us know what you find.
ChrisV
Any m26 that have an Scx with an extension box? Feel like the box makes the porpoise worst imo.
Orangegazm
Doesnt @CammdSS mach have a standoff and scx? I would assume the standoff would reduce the porpoise, but I've never been in one. @Orangegazm would know
A stand off with a Bravo style prop will make the boat porpoise. I have a #6 drive and finding props to test is tough, I thought the boat needed tail lift with the extra weight of the drive/transmission... I was wrong, the boat wanted bow lift. I had a 4 blade cleaver turned into a chopper and the boat absolutely loves it. I want to try a 5 blade cleaver with 18-20* of rake, I think that will be the ticket. I will have more power this time around so a new prop will be a must.
ChrisV
@CammdSS
Judd been helping me with my boat and we were talking about your build yesterday. Can’t wait to see it.
Side not:
I love the stand off but low key want to take it off.
Orangegazm
@CammdSS
Side not:
Judd knows his stuff, we've been friends for long time.
CammdSS
@CammdSS
Side not:
I havent driven a 26 without a box so I couldnt tell you whats better. Im with @02HoWaRd26 - through many peoples thousands of hours of testing in the past, having the extension box should decrease the porpoise. But again, I havent A/B split tested it. Thats just from the research I have done as well.
Mine hops from 65ish-75ish but I never stay in the hop. I tried it once, held 70 for about a minute and it was like riding a bull trying to buck me off. I either stay under or over but I never look at the speedo. With the power itll get through it in 3 seconds when my foot is to the wood. I still only have about 10-15 hours on the boat so I really dont have a good baseline, I'm not much help here.
Im sure tab length and drive height has an impact idk every boat set up is different
Guest06
So mine starts at 60, and goes till 70. There’s some tricks like a jiggle to the steering to help stop it, but really only way is with power.
JDizel
Thinking about letting her go / testing the waters. 2005, hp500, XR, half cap, super sano, beautiful boat. Any interest out there?
J.P.
Its a 2000 year model 598 with 1471 Littlefield blower, Bravo XR with Imco SC lower. I run it on lake Conroe and have had it on lake Livingston and Travis. I have owned it since 09.
toto
We are in the Dallas area but we plan on making a run down your way this year and I will hit you up when we do. You don't see to many DCB's in Texas 😁. We have a Mach 22 but it is still fun.
ChrisV
Getting use to this boat and loving it. I wouldn’t be able to live without the tunnel tabs. Definitely a game changer.
ChrisV
Do those tabs make a difference on the 26? Been debating some on mine. Not sure if it will help with the hop I get, or plane faster.
Helps with both. You won’t regret getting them
Boat211
I had tabs on a F26 I owned with outboards. I was able to completely eliminate the hop at any speed. I really liked them.
N2DEEEP
Perfect what’s the length of yours. Btw Congrats on the boat. I remember when you Mentioned you were looking for a Mach 26.
Btw! Was anyone on the water today?! What a beautiful fk’n day today. Water was chill and crisp and the sun didn’t beat us up too bad at all.
ChrisV
24”
Thanks man! Family loves it. Kids love sitting under the dash area.
