? For Boostpower, Teague or anyone else
Instigator
Just Livin up to My Name
Looking to find a current part number for replacement injectors for a 1999 Merc HP 500.
Merc Part number 8M0070081 is no longer available and it doesn't supercede to anything that I can find available either.
Maw
Dont re Member
You might try these folk, I've bought a few oddball injectors there over the years.
Teague_JR
I remember hearing something about TCM finding a suitable replacement.... call BT
bonesfab
Are the old ones bad? I have a ultra sonic cleaner and flow bench for them.
Instigator
Boat has been sitting for 8 years so I don't want to chance cleaning them rather replace them with new.
sintax
i'd try @bonesfab's option first, why throw good money at something that doesnt need to be replaced. If you're that worried, have them flowed.
we're not talking about a $20 part
3queens
Detachable Member
that looks to be a oring kit #
give these guys a call
is this your set up ?
Instigator
Item 25 in your 1st pic is the injector assembly for the 1999 merc racing hp 500 which is what I'm looking for however the part is NLA from merc.
Do you have a flow rate for them? Probably in the 40lbs per hour range
1999 injectors are some old ass tech, more than likely bad spray patterns, drippy, inconsistent flow. DaveH next door has the ASNU machine, those old injectors many times are just worth throwing straight into the trash can when you can buy a brand new OEM injector for an LS for like $40 a piece.... Normal price for a flow and cleaning is $25 per injector, soooo.
Probably worth putting modern injectors on it in the same flow rate arena and possibly a quick reflash, Alexi would know if there is an injector that is close enough in size to not warrant a flash.
Instigator
I agree with you in throwing them away. The risk of one running lean just isnt work the money. Problem I'm having is finding the new ones. Which is the whole point/question of my OP
Yeah or having one stick open and wash the motor down, almost the more likely scenario.
Call boostpower, he will know exacly what the Lbs per Hour those injectors are and what is the best replacement.
3queens
Detachable Member
look at the other links shows they may be replacement for old oe numbers the lucas brand may work
shows the old number in the replacement product 8m0051200
farmo83
If you really want replacements I would call Bob. A while ago I needed a part mercury hadn't made in 15 years I was told. Bob had one on the shelf and got me back on the water.
That having been said I would go modern an call Alexi. He's awesome to deal with and knows more about efi then everyone else has forgotten
This!! Personally a flowed, equalized injectors are better than a stock one. But I’d remove and see about finding a similar set from an LS then have them flowed and equalized as well.
sintax
you gotta pull em out anyways to replace them....
Might as well flow the old ones, see how the do. If they are good you just saved yourself $650-$750.
Instigator
Your link doesn't work. Says system down.
John @ Boats Unlimited has direct replacements. He is a member on here as well.
817-658-7721.
3queens
Detachable Member
38lbs, Lucas USA, D1163BA, New Parts
try to google this see if it gets you there
or google D1163BA see if that works
