Gen 5 Timing Chain and Gears ???
Rickybobby
I ended up pulling my motor after all and it was suggested that I change out the timing chain while I have it this "far apart". What suggestions does the gallery have for a replacement set ??? I have had problems finding a set for my Gen 5 motor. Can I use any mark IV set ?? So far the only thing I can tell that is different as far as timing is concerned is the number of bolts that hold the cover on ???? Please correct me if I am wrong and suggest a good quality timing gear and chain set for my Cruiser motor (ie stock or near stock Indmar horsepower, of 1996 vintage).
thanks in advance
rb
Hammer
I would go with a nice single roller timing set would be fine for your application . That are relatively inexpensive considering...
I'm sure comp cams , cloyes and others make a set for your engine. Have you tried summit or jegs ?
I'm not sure if you can run a gen 4 timing set...
welldigger00
The difference is the gen 5 has a camshaft retainer plate, that registers on the end of the camshaft. Also the timing gear bolt circle is smaller. I used a cloyes single roller on my build. The chain is bigger, almost like a 520 like dirt bike chain.
Sent from my iPad using Tapatalk HD
obnoxious001
Engine building character
thanks in advance
rb
The suggestions are correct, it has to be a dedicated Gen5/6 timing set, and if you are retaining the stock cover, will need to stick with a single roller type chain. Depending on hours on the engine, you could even just put a new GM chain on and be good,, (I believe Summit sells them as well)
RUNNINHOTRACING163.1
Great post BIG Daddy :drink:drink:drink:drink
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.ebay.com/itm/LED-BOAT-DR...ain_0&var=&hash=item2c6a87c5ea#ht_9068wt_1117
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!! :champagne :champagne
Rickybobby
obnoxious
Thanks for the reply. The motor has a Glennwood Marine (10bolt??) timing cover. Is that the same size as the stock cover ???
Welldigger
Do you have a # for that unit from Cloynes ??
obnoxious001
obnoxious
Welldigger
thanks again guys for the help... need all I can get... View attachment 269763
The Glendwood cover should allow a double roller chain set, just make sure it's one for the Gen5/6 cam pattern. For whatever reason, they are higher priced than the MK IV style.
welldigger00
I'll take a look at my paperwork and see if I can dig it up. I got mine from ray at Dougans machine in so cal.
racerden
Boat #197
Summit sells a very nice double roller gear KIT complete with Torington thrust bearing. I've installed dozens of these P/N #G6610B. Good stuff
