Big Chorizo
- Nov 21, 2017
- 201
- 240
Look and see how big the washers are on the back side. Does it appear there is solid core? What kind of boat?View attachment 664499 If said tow hook was to pull a 3 person tube? I realize it doesn’t have the weight capacity of the floor or engine mount pole style. Just trying to prevent ripping it off the boat.
I've pulled a 3 person tube behind my cheetah off of that same hook. No issues. But like stated, it wouldn't hurt to use large washers, or even glass in a wide support board behind it to spread the load if it's something you are going to be doing a lot of.View attachment 664499 If said tow hook was to pull a 3 person tube? I realize it doesn’t have the weight capacity of the floor or engine mount pole style. Just trying to prevent ripping it off the boat.
This has me wondering what you would tow a boat from?
I use a side cleat on both sides back to a triangle shape that goes to the tower vessel for long tow... short .. 1 to 2 miles I use one side cleat. Depending on weather, water conditions.
Number one rule / tow to closest ramp, take a driver WITH KEYS FOR TOW VEHICLE... to their home ramp. Let him go get the boat. (Exception would be if on Havasu and their home ramp is casino)
If I’m headed to home ramp, I may tow all the way if not in a hurry.
The boat is a 2001 Eliminator. I’ll look today to see if there’s any washers or backing plate.Look and see how big the washers are on the back side. Does it appear there is solid core? What kind of boat?
I don’t think I’d worry about 3 people in a tube.
Not sure I’d pull another boat from that point.
Just don't tow fat bitches....![]()
You've absolutely never read the article in Motor Boating, about a good guy, given a tow to a broke down boat. He offered his own rope attached to his cleat. The cleat ripped out of his boat and the swung towards the broken down boat, hitting the guy in the head while he was sitting on his deck. The good guy was sued for damages. I should dig out the article, it was quite a story. Make note, don't use your own rope to tow someone else and never use stretchable ropes to tow anything.The rope would likely break before the hook or its mounting would fail.
Yeah, yeah, we heard you the first timeThe rope would likely break before the hook or its mounting would fail.
Yes, this was an option I was looking into. For $20 its worth not having to worry about, only bummer is it places the rope very low in the water.If concerned there is a heavy tow bridle for larger tubes that connects to the two tie down rings on the stern.
I actually think that's worse than the tow hook. There is almost NEVER any kind of backing of any substance below those cleats. That along with the fact that the rope is pulling them on an angle to the mounting bolts and surface, they are more likely to get or cause damage than a correctly installed tow hook in which there is likely some backing if it's not through the transom itself.I use a side cleat on both sides back to a triangle shape that goes to the tower vessel for long tow... short .. 1 to 2 miles I use one side cleat. Depending on weather, water conditions.
The bridle set-up would greatly reduce the potential damage but it's still much more likely to damage the boat from being pulled on the cleats than on the ski tow IMHO.
I towed a 26' playcraft from sand bar to pirates with that same style hook with my cheetah that was a long rideI've pulled a 3 person tube behind my cheetah off of that same hook. No issues. But like stated, it wouldn't hurt to use large washers, or even glass in a wide support board behind it to spread the load if it's something you are going to be doing a lot of.
Talked with a couple guys at the shop today.The boat is a 2001 Eliminator. I’ll look today to see if there’s any washers or backing plate.
I just changed out the tow hook, vent plate and handles on the back of my 98' Eliminator Eagle. Only a washer for each bolt on the tow hook. And nothing on the vents / handles.Talked with a couple guys at the shop today.
Both said to look see what’s up on the washer and nut side.
Both said pretty much the same thing. If you’re going to do that they suggest fabbing a simple aluminum backing plate.
Kenny Smith added that in all his years he’s seen exactly two of those fail.
I think I’d find me a small piece of plate and address it personally.
I just changed out the tow hook, vent plate and handles on the back of my 98' Eliminator Eagle. Only a washer for each bolt on the tow hook. And nothing on the vents / handles.![]()
I have towed boats, skiers and tubes over the years without a problem. I don't ski or tube anymore so I'm not worried. lol
All I can say Bobby, is that was then and this is now.
They’re making some changes and shifting some employees focus a bit to make things brighter.
As good as they are now, I believe even the haters will be standing back and saying...Daaaaayum!
From what I understand the bridle splits the tow weight evenly 50/50 (if bridle is properly set up) between the 2 connection points which would reduce the load by half going to each point. If bridle is long enough it won't pull at that much of an angle, not enough that would pull the D or side cleat out sideways, IMO. You do make a good point about the backing.
My Dad had his 240 towed back to dock from a mile out of marina. He and I were both surprised to see the towboat side tie right next to him then motor in. Obviously provided great maneuverability right at the dock though.
Thanks for the info, here’s a shot of the back side, nothing special. I think adding a plate is a good idea. For now, until I get time, I will most likely grab a bridle strap for now.Talked with a couple guys at the shop today.
UCHs tow hook is held on with 3 or 4 10-24 screws.....
Scary.
