Cole Brewed
- Jul 17, 2018
- 709
- 1,279
So I purchased my boat this summer and I have really enjoyed it. I do recognize a few systems that need improvement or correction.
The most important to me is the steering. I found a thread from 2015,
( https://www.riverdavesplace.com/forums/threads/hydraulic-steering.138616/ ) that is helpful, thought doesn’t entirely address my situation.
The boat, 1996 Cole Nighthawk, PFAFF power 650hp, Bravo 1 drive. Imco Dual external hydraulic steering rams, cable to valve assembly control.
I know the boat does 76mph on gps, with much more throttle to go. The first identifiable concern is when cruising and a mash to the pedal, the boat reacts very quickly with an abrupt move left or right, and also an abrupt lift of the pedal the same though opposite abrupt moves. People have mentioned torque thrust may cause this. By no means am I a specialist, but I think the seals in the external steering rams are internally leaking and may rebuild. I do not have an external power steering fluid leak anywhere.
I do not know if the valve assembly is a Saginaw or Brazilian type. I thought I read somewhere the was a change around 1994…..my boat is a 96.
My intent is to rebuild or replace the rams, and to convert to a complete hydraulic to helm system. With that said, my next concern is the space necessary for the hydraulic helm. My helm is pretty busy.
I will be having the throttle and forward/reverse cables replaced, and the speedo.
Lastly, I’m looking for a reputable, qualified shop references for the installation. I have only enquirer with one shop in Boulder NV. I am will to travel to Vegas area, along Colorado River, and So Cal.
Another area to address is the stereo system. Basically the components are there, I want to know they are set up and functioning correctly.
I appreciate and value RDP members input. Thanks in advance.
