FROGMAN524
- Mar 16, 2013
- 6,493
- 12,734
Almost blew up my house yesterday. I have a 2019 KTM 300 XC, last of the carbed KTMs, and it's got less than 20 hours on it since new. I installed a Lectron Mule H-Series 38mm carb on it September of 2019. It has been kept in my garage and had new fuel in it every 6 months or less whether it gets ridden or not. Yesterday morning as I was leaving to go to work, I opened my garage and a very strong smell of gasoline hit me square in the face. I turned on my iphone light to see what was going on as I did not want to turn on any electronics including the overhead lights for fear of causing a spark. With the iphone light as my guide, I discovered that almost 3 gallons of gas had leaked out of my dirt bike over night while we were sleeping and it turns out the carb bowl power valve vent line had broken while I slept, and because the float seat was bad, it let all of the fuel out as my petcock was on. I then cautiously opened the garage door and sprayed all of the fuel out with a hose and then scrubbed the entire garage and driveway with dawn dish soap. After getting everything clean and the fumes dissipated, I called Slavens racing and the guy that answered told me the same thing happened to him on his SmartCarb and that Lectron has since changed the design going internal with the power valve line on the new Lectron Billetron 38 carb, which I then ordered, along with all of the new vent lines and rebuild kit, so I can fix and sell this older Lectron if anyone is interested. Additionally, with the older Lectron you had to remove the stock throttle cam and cable, which I sold with the original Keihin carb, and thus had to order again from KTM Parts Pro.
We are very lucky my gas water heater in the garage did not ignite the fumes.
Here is the culprit:
Here is the new redesigned Billetron 38 with choke moved to the left side, idle and power valve screws on left side and power valve line internal.
