SpectraPat
- Mar 21, 2013
- 594
- 496
Any one know where I can pick up a pair of these hinges?
Thanks!Hey Pat, you may run into an issue with those, not sure if the spectra will have enough room to swing up inside deck. I used these from Eddie Marine... I made a 3/8 plate to hang the hinge in and spread the load out.
That was my 24 schiada and I had Scott Kornaski make the hinges and the fiberglass hatch while it was getting the interior done at Bill Sturgis place.Those hinges are made by Stan at Schiada. Not a part you can just pick up.
Did you ever come up with a solution regarding the hatch hinge? I'm not clever or talented enough to make my own, looking for a "over the counter" hinge and what you are looking for is exactly what I want. ThanksAny one know where I can pick up a pair of these hinges?
View attachment 919189 View attachment 919195
These look pretty good. $70.00 for the pair seems reasonable. would you mind posting a few photos of your install? Thanks!!You can try these if you have the room. I’m modifying the ones I bought. Good luck!
Universal Trunk Hinge Kit
Making your trunk functional doesn't have to be difficult. Our universal trunk hinge kits can help get your trunk working the way it should. You have the choice of stainless steel or zinc finish to give you the look you're after. Universal Choose stainless steel or zinc finish Pivot point to...www.speedwaymotors.com
