Need a MacGyver suggestion......pool filter leak
ONE-A-DAY
My havasu pool filter took a crap today, split, and is now leaking (see pic). My pool guy will have a new one installed on Monday but I was wondering if anyone had a suggestion to stop the leak so I can run the filter this weekend.
JB weld?
Ziggy
SlumLord
Same happened to my sons filter housing. Some good sanding inside/out at the crack and a generous coating of Marine Tex(JB Weld like) inside and out and its been fine for several months so far:thumbsup
Outdrive1
I wonder if you could epoxy a patch from the inside? Clean the filter so the head pressure is low.
Outdrive1
Marine tex dries pretty hard.
wallnutz
Clean it up real good, sand it, and then some Home Depot fiberglass and resin. It's easy and cheap.
jscarab
Master Blaster
Don't run it.....not worth the risk of blowing out and partially draining pool. Also looks like the water will be shooting right on the pump motor. Not a good spot to be in......new filter housing on Monday, only have to tear the filter down once. Gonna be storming all weekend, get it replaced Monday and the filters cleaned and clean up pool then. If you're worried about chems, use a little liquid chlorine. I have seen many repairs to filter housing only to break in another spot soon!!!
2FORCEFULL
yep been there done that,,,, blew the top to the neighbors house...
the patch did work for a day....then exploded
i'd wait till monday
OutCole'd
Raging Member
Mine cracked like that. I called Pentair, they replaced it for free under warranty and it was about 10 years old. Shipped a brand new one to my house.
JB in so cal
I talked to them. They comped you cause they didn't want to get sued for keeping the little man down. Lucky.:D
TCHB
I would just shut the pump down for the weekend. We should have new rain water in the pool my Monday.
Outdrive1
Funny I had a pool ordeal today.
So I've been hearing the leveler run at night. I can hear it in our bathroom as the fitting is tapped into the hose bib right outside the wall. I figured its been hot and probably takes quite a bit of water to compensate for evaporation. But then I notice it runs all the fuckin time. Day and night.
So this afternoon I get a free minute and I figure I'm gonna see what I can see. Flip on the pump, and its right there at the pump. The screw in 2" fitting. Ok well it's a new pump. I changed it last year, but I had the old pump rebuilt a couple of times too. So the 4' of pipe had at least 5 couplers in it. I figure I should start fresh. New elbows, pipe and fittings. No couplers. Lol.
I do the HD run. Get all my shit. Cut it, dry fit it, glue it all together. Paint it black again. Wait two hours and test it. Wouldn't you know one of the elbows is cracked. Seriously??? It's all brand new. Fml. Lol. So back to Home Depot. New everything again. Ran it, no leaks this time. Paint it again.
Looks like I'm good for a couple of years again.
Fuck pools.
OutCole'd
Raging Member
Fuck pools.
I have yet complete a home repair with only one trip to HD. It always takes at least two, sometimes three trips.
I have that same filter. Good to know. Thanks! :thumbup:
Tapatalk 4.0
rivergames
Epoxy that fucker and enjoy the weekend. Fix it next week and fogwttaboutit:thumbup:
ONE-A-DAY
House is only six years old, I'll call them
aka619er
That Guy.....
Use that Billy Mays spray on stuff. If it will fix a gutter and make a screen door float your pool filter should be a piece of cake. Or one of his other commercials. Magic putty..... lol
Sandlord
JB weld the inside, fiberglass the outside, coat both side with the Billy Mays stuff, then wrap it with duct tape and use a cookie sheet for a scatter shield, just in case.
Or maybe call Chicken-Dan, he's a real McGyver.
lebel409
Youngster. I have boxes of parts now, all left over from when I needed a screw but they came 6 to a pack. I only need to go every 4th honeydo or so:D
nordictom
I had the same problem, go to Crystaliner (sp) in Costa Mesa. They have everything you will need to fix this & will probably tell you what you need & how to fix it, really helpful staff. My repairs are going on 3 years, my pool guy can't believe it.
NT
Just fuckin knead it to activate it :D green to white technology
[video=youtube;OedkugcgIxQ]http://www.youtube.com/watch?v=OedkugcgIxQ[/video]
In all honesty, Marine-Tex and some mesh drywall tape would be my choice.
Antonio D. Word
New Member
There are very less I seen that the pool filter get cracks. But as other said its not a big problem you have to wash the pool and fill the sand. Use a piece of silicone at the crack.
BHC Vic
cobra performance boats
Man too bad it's not local I have a bunch on fiberglass patch stuff from my
Jet ski hull I just repaired. It's not expensive but I won't need this stuff anymore
rrrr
This post needs a Hanslator.
08-22-13, 08:44 PM
He probably has it fixed by now. :D
Kachina26
Inmate #RDP158
Flex seal...
[video=youtube;vwU8JObQMXc]https://www.youtube.com/watch?v=vwU8JObQMXc[/video]
