Rzr front end issue
Joker
The kid hit a rock and punctured the sidewall and I now see that tire is pushed back 2" compared to the other side.
Any ideas on what may be wrong?
Uncle Dave
Bummer
Hard to say without seeing it. The stock stuff is lightly stronger than a wedge of aged Wisconsin cheese.
We might still have a zero hour completely stock front end at the shop sitting in pieces as my Madigan build basically turned all that into a take off.
Got a pict?
U Dave
Joker
If I'm looking down inside the wheel well, the upper a arm isn't centered vertically with the lower. Almost like its rotated to the rear?
throttle
c ya on da lake
Oh no. Always something.
Btw, The new tires look nice.
thmterry
I have seen bent a-arms and the a-arm mounting bolts being bent. I have 3 of the 4 a-arms off a 2009 RZR 800. I took off when I did new long travel.
We've had guys roll into camp after hitting something or a witch eye.
If nothings bent or damaged you can re-adjust the alignment.
Look for the threaded bars with nuts on them.
You measure across from the inside of each rim with a tape.
That may be it.
This is somewhat similar:
[video=youtube;jdIWiIwvyQ4]https://www.youtube.com/watch?v=jdIWiIwvyQ4[/video]
Joker
That may be it.
I talked to the guys at the store and they said if the wheel was pushed back, most likely an a arm. I can't seem to see a bend with the a arm though.
They'll have to see it..
Joker
Boy, now I wish I had a trailer. I don't think I should drive it from the house as its a good 20 min.[emoji107]
thmterry
Look at the a-arm right on top of the ball joint and look for cracked paint. If you are driving on dirt you shouldnt have a problem, street you could wear your new tires.
2FORCEFULL
measure the A-arm bolt to the spindle on both sides of the spindle and on both sides of the car...
also look at the bottom of the frame and see if the frame is pushed in on the passenger side
Joker
17" on drivers side, 18" on side that is pushed back
plaster dave
Face down A$$ up
John I have a flat trailer on the side of my place if you need to use it. My rzr is there too if you can't fix yours.
Driving on dirt you'll be OK. Streets will just cause the tire to wear a little more than the others. You either bent the spindle, an arm or the frame where the arms are mounted. Or a little bit of each of those. That sucks. Glad everyone is OK. Stuff can be replaced, people cant.
Joker
Ugh, guess I'll limp it down to the dealer.
Thank you though
Joker
Havasu dealer said it sounds like a bent frame. ?
Uncle Dave
Whole things cheesy out of the box.
The A Arms bend easy as been said from a sand shark/ witches eye / mild collision - and they bend when you land on one wheel from jumping - the spindles shear off easy as well.
Heres a pict of the parts off the car.
UD
Joker
I was able to drive it to the dealer. They are going to look at the front end but he said nothing looked bent. They are gong to check the tie rods. Also said the 2" difference may be normal.
So much for trying out the new tires.
I'm glad you got it over safely.
2" is an acceptable amount of difference with regards to their finished product? Is that what they are telling you? That it's OK for the right front tire to be further forward or back when compared to the left front tire? That's awfully strange and doesn't sound right.
It sounds to me like someone who doesn't know much is trying to convince you that everything is OK with the car. It doesn't sound right to me, but I'm just a fellow RDP'er.
My front end on my Toyota truck isn't 2" off that's for damn sure. ;)
I'd push the issue if this were my situation Joker.
Joker
It's clear that it's 2" and he said the plastics on the rzr aren't ever perfect. I couldn't find anyone else here to take it to.
Devious_Chris
I wear sunglasses, lake Havasu city az.
Bullhead on the parkway
In my experience the front section of the frame can bend causing this to happen. You could also have a bent A-arm or bent mounts. We have repaired several at my shop.
stoker22405
A buddy of mine had the same problem on a 4 seat rzr 800.....I think his ass still hurts after paying the repair bill....!
Joker
Dealer in bullhead says no parts are bent and they will try to align it. I honestly don't think they know what they're doing. I asked them about the frame and they seemed puzzled how to determine that.
Joker
Where is your shop?
Joker
When you drive down a paved road,what happens when you let go of the str wheel,Veer off at all?When you hit the brakes,still normal or veer off?
Heads to the left regardless. Will not stay straight.
Joker
The welds look different on each side of the frame. Like one is opened up?
Joker
Ok, guess I'll tow it back to OC. Where is a good place to get it looked at? Havasu Dealer is 3 weeks out on service.
rivrrts429
Arch Stanton...
To me it looks like they missed the joint originally?
I think you're right, 75% of the weld is off center.
The picture makes the weld look like its fractured or its just scratches from bushes, hard to tell.
