2FORCEFULL
- Jan 26, 2008
- 28,989
- 17,745
WHATS BETTER ,,, to just sand the bottom and leave it or speed coat???
and also who does it now??
Rolling or spraying a speed coat is as easy as it gets. Just buy a can, rough up the bottom of the boat, and roll it on.
I really want to try the new golf ball texture on a boat. Seams like that would be the best way to go
I had a conversation not too long ago with Rankin on this subject and he said its worth 2-3 mph in his testing on the SS80. So I guess it depends on if you want every last mph and I'm sure it also depends on the efficiency of your particular boat. A lot of guys use it (racers) as it is a steady seller over the years. For recreational boat probably not worth the bother. We also have used it historically on racing skis, roughed just a bit with good success. It makes a difference in the slip and ride of the ski (effort). But ask 10 people about speed coat and you'll likely get 10 answers that don't match.![]()
Is anyone going to try FISH SCALES, AGAIN?????????????????
HARLAN ORRIN
How long ago was that tried Harlan?
You looking to try something new Aaron? LOL
There was a mold built for a flat bottom in the early '60s. I never saw it or heard how it ran.
HARLAN ORRIN
The golf ball dimples are all about lift and have nothing to do with reduced drag.
!971 Mize flatbottom.
that is entirely untrue.
I probably could/should have worded that differently, they do reduce drag, but they provide a significant amount of lift. I would not put dimples on the bottom of my boat.that is entirely untrue.
They provide a significant amount of both. Spheres and cylinders are uniquely suited to dimples. Planar surfaces (like a wing or boat hull) are subject to skin friction drag instead of pressure drag like the golf ball. The dimples create a more turbulent boundary layer which causes a low pressure area behind the ball.
Cool thread! Tried golf ball finish and it slowed boat down considerably. Best numbers we got were from gelcoat sanded directionaly and waxed with kiss kote
