Beeconinc
- Nov 12, 2018
- 10
- 6
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
View attachment 751022 View attachment 751023 View attachment 751024 View attachment 751025 View attachment 751026 View attachment 751027 I have a twin turbo setup for big block Chevy or ford. The only difference is the manafolds. I used this setup on my boat then I let the boat just set for along time. I am now redoing the boat and building a bigger motor with twin turbos. This setup would work Great on a stock Ford or Chevy motor that you want to add serious power to without compromising the reliability of the motor. Turbo work Great on jet boats to the RPM range there is almost no lag because with the jet you’re always have the rpm up. Any question just call or text. It’s been a Well since I had to set up on the motor but I should have everything you need and be able to talk you through what you have to do to get it on your motor. I also have stainless steel IMCO water jacket exhaust. 2500.00
Could you please call me regarding your turbo set upView attachment 751022 View attachment 751023 View attachment 751024 View attachment 751025 View attachment 751026 View attachment 751027 I have a twin turbo setup for big block Chevy or ford. The only difference is the manafolds. I used this setup on my boat then I let the boat just set for along time. I am now redoing the boat and building a bigger motor with twin turbos. This setup would work Great on a stock Ford or Chevy motor that you want to add serious power to without compromising the reliability of the motor. Turbo work Great on jet boats to the RPM range there is almost no lag because with the jet you’re always have the rpm up. Any question just call or text. It’s been a Well since I had to set up on the motor but I should have everything you need and be able to talk you through what you have to do to get it on your motor. I also have stainless steel IMCO water jacket exhaust. 2500.00
If his sold, I have a Banks kit that I have not yet advertised, located in Parker, AZIs this sold?
Sorry, I haven't been on here in a while. I would like more info on your Banks kit.If his sold, I have a Banks kit that I have not yet advertised, located in Parker, AZ
