SHEP
- Feb 1, 2008
- 1,234
- 468
How often are you supposed to flush the tank for your water heater?
Thanks,
SHEP
Thanks,
SHEP
Thanks,
SHEP
I don't think just draining the water heater really gets out the sediment. That stuff just sits at the bottom of the tank, and it is below the drain fitting.
Maybe if you hooked it up to a hose and power flushed it you might get most of it out. But who's gonna take the time for that...?
Why Draining Your Hot Water Heater Might Be a Mistake
This thing happens in the DIY blog-o-sphere. A plumbing expert gets up on YouTube and gives a tutorial of how to clean out the sediment from your water heater. You've read a bunch of articles online, on websites that even look reputable(!), and they tell you to empty your water heater and flush out the sediment. They don't mention one important caveat: It's a very good idea to remove the sediment from your tank water heater; but if you haven't done it in years, flushing your water heater will cause problems you have never imagined.
This is what can happen to your water heater if it has been collecting sediment for years, and you suddenly drain it: your water heater will spring a leak. According to Woodbridge Environmental, an Elizabeth New Jersey contractor and home inspector, who brought the topic up on Hometalk.com, "In some towns where they flush their fire hydrants to keep the pipes clear it is suggested to follow their lead a few days after as any sediment that is disturbed ends up on the bottom of your heater.
"What happens then is water displacement. The sandy partials that collect on the bottom of the tank displaces the water ever so slightly. This results in hot spots on the bottom of the tank. When this occurs the flames overheat the tank and begin to break down the steel. After many years this breakdown ends up becoming a tiny hole that is filled with this debris, oftentimes preventing the leak."
"However if you decide to drain your heater after many years of not doing it, or all of a sudden you start using the heater more then normal, this sediment that has been plugging that tiny hole is flushed out, often resulting in a leak in a few days after."
"So the moral is to flush yearly, but if you have not done so for many years to not touch it or you will end up with a leak."
I just replaced both 100 gallon hot water tanks in my house. They are gas. They were Rudd's and lasted almost 12 years. One started a small leak so I just replaced them both.
Plumber said every six months for the flush. Also check the rod every year as it will probably have to be replaced every two years.
Two 100 gallon hot water heaters? How big is the house?
I believe it. Last three I attempted to flush/drain, the drain always leaked afterwards & ended up putting a cap on it so can imagine what's going on inside. Wife has talked about the water heater at our weekend place & I imagine it would be a can of worms messing with that thing. 16 years old & never been touched, but still great hot water & no issues so I ain't gonna try fixing what ain't broke, lol...
If it is in a place where if it leaks, it causes damage, I would replace that thing. Not gonna be cool when you come to your weekend place after two weeks away to find that water has been running for a while. :eek
If it will drain away on its own, worst case is a big water bill.
It's the city. They did it based upon shower heads and bedrooms. The house is not that big.
It is total overkill for two people.
I drain and flush mine every year. 50Gal Bradford White, still works great after 28 years![]()
I have a filter bigger than that on my main line coming in the Havasu house. Turns some interesting colors when fill of sedimentI have a $40 sediment filter on my water main just before the water softener. It was highly recommended by my contractor when the house was built. It's cheap insurance. I use the 5 micron filter and change it every 3 months. There is a significant amount of silt in the filter/housing after 3 months that I'm glad is not accumulating at the bottom of my water heater or plugging up my softener.
I'm on 11 years on my water heater without any issues. I also set the dial to "vacation" before I leave to go home.
Our gas water heater lasted 22 years - never flushed it, but I have a recirculating pump that runs 12 hours a day. I think that's the secret
Not to hijack the thread, but I read an article awhile back warning not to drink or cook with water from the hot faucet.
A couple had 2 Golden Retrievers or Lab showdogs. One of the dogs got very sick and his kidneys were failing due to severe kidney stones. The other dog also had issues, but not as serious. The Vet asked them a number of questions about diet and fluids given. They were using hot tap water to mix the dogs' food each day and the Vet felt the minerals from the water heater were causing the kidney stones.
The owners started heating water from the cold side and the second dog improved over time, but the first dog was too far gone. This issue is kicked around in the medical industry and undecided either way. But I have stopped using hot tap water in all cooking processes just to be on the safe side of things.
Something to think about anyway.
