Water In Pontoons. How To Get It Out??
RogerThat99
Parker Is Now OPEN
My Buddy has a Suntracker pontoon. He can hear some water sloshing in the pontoons. He doesn't think the pontoons have a drain plug (the boat is in storage, so I couldn't look at it).
My question is: Do all Pontoons typically have a drain plug? If not, water is the leaking in through a weld. Is this common?
How hard is it to add a drain plug to the pontoon.
He is going to be putting the boat in a slip, and is concerned about water leaking into the pontoons.
What are your thoughts?
Sent From Tapatalk
JayBreww
Sent From Tapatalk
Weld a couple bungs on the rear and be done if it don’t have any. I’m sure the prop shop could do it in a hour or so.
Pivot
He needs to take a better look. Very good chance there is a drain at the rear of the log. As these get welded at the factory the actual weld creates heat. Which creates pressure. If you don't let the pressure escape the last few inches of weld as the log seals is damn near impossible. Your weld puddle will blow out
ONE-A-DAY
Most don’t come new with a bung or drain, we had a leak in one of our benningtons, lifetime warranty on the toons so the drill and tap a bung and fill them with air and the do the old windex thing to find the leak
Beautiful Noise
I have a 2005 Suntracker no they don’t come with drain plugs, I had to have plugs added a couple of yrs after I bought it. Was told they had to run a long drill bit to put holes into the front chambers for the water to drain. Seems like every couple of yrs it starts taking on water then I need to get the welds checked and fixed. I use pipe compound on the threads when screwing the plugs in to seal. If I leave it in I usually pull it out after a couple of day to gas it up and check just for a peace of mind👍
My brother in law's beater/rental toon developed cracks where the deck mounts to the log. Factory bracket welds cracked. Most likely in his case from smacking docks with idiots driving. Son of a bitch, hard to get in between the center pod and the log to weld it back up!
throttle
c ya on da lake
bung hole.... [emoji23]
HALLETT BOY
Last boat show I looked at some toons , could not believe the sloppy / poor welds . Check the welds .
Waffles
The plugs are there....its just not where youd expect them to be. My 04 Suntracker had the plugs hidden between the skirts on the top of the log
Pivot
yeap, some real bad welds on pontoons. Good thing is they now go 70mph!
havasujeeper
With my 2001 Suntracker 22 Regency, I utilized the small red plugs on top of the tubes to insert a siphon hose. I let it drain until the next day and got 20-30 gallons of water out of it. My next step was to weld a bung hole and the back of the tubes, but since I rarely used it, I sold it "as-is" to my neighbor.
baja-chris
Is Skips still around, can't find them? Both the outer logs take on water (slowly), I think see a failing weld on one of them. Out of warranty.
Who can test, find leak and repair in Havasu?
Tank it in Havasu is one I see recommended often.
n2otoofast4u
Called Liberty now. Definitely still around.
Reactions: DWC
zhandfull
My toons leak a little after 25 plus years of beaching. Guess that’s to be expected. Have drain plugs on back of each toon. Not sure if they are factory or have been added by previous owner. If I was going to slip it I would want to fix the leaks. But I don’t so I deal with it.
Just notice an old thread was bumped. Maybe I’ll see about getting my toons welded too. 😁
RogerThat99
Parker Is Now OPEN
My buddy, who had the water, sold his toon a few years ago.
